Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #4,861
I have experience with both FEL and blower. Blowing may not be as fast but does a **** of a better job than banking the driveway. Bonus inside a heated cab is better than sitting in the open air with a FEL. I guess it is to each their own and I prefer blowing over plowing any day.
   / Pictures of your snow weapons #4,862
That picture is a portion of the compound at the top of the hill. There's a half-mile of road that heads downhill to the right... with a 150' elevation change. No way I'd use anything but my 9' plow (or larger if I had it) on it. Snowblower would take forever.
   / Pictures of your snow weapons #4,863
Here are few pics of my snow removal
Front of the house, my driveway and my neighbors who plows his with a FEL quite a difference from snowblowing.
Those images also illustrate a point I haven't seen mentioned... if you live in blowing and drifting country, that snow-blown driveway will be a heck of a lot easier to clear after it drifts shut overnight VS if that plowed driveway drifts shut between those high piles.
   / Pictures of your snow weapons #4,864
I’ve been using the truck and plow for nuisance snowfalls, ie those less than six inches.
Deeper snow I use the tractor / blower. I also have to use the tractor / blower about every ten days or so when the piles left by the truck use up all of the available space, and when the snow along side of the deck exceeds 4’, and you can’t push it off the deck anymore without shoveling up.
Another week or so and we’ll head to Arizona and San Diego for a month. Spring starts arriving in mid April.
   / Pictures of your snow weapons #4,865
If speed is paramount each has their particular advantages depending on conditions. Plow can be very fast for relatively small accumulations if there are no snow walls and you can throw the snow to the side on a single pass. Plows are also faster in slush conditions than a blower. If there is moderate to significant snow walls however, in my experience, a blower is faster. Plowed snow in those conditions just falls back into the lane so extra time and care is required to push everything "back" and which point a blower is likely the faster tool.
Regardless of the time involved blowers produced a nice clean finished product that many homeowners appreciate, and don't leave hoards of gravel all over the lawn in the spring. A plow can get down to the gravel/concrete or pavement easily with each snowfall and leaves less of an ice buildup as the winter progresses.
If you get into a situations of 4 foot plus accumulations as the winter progresses a sub-compact with a blower can do much quicker than what the otherwise "heavy equipment" plows or loaders would otherwise be required for the job.
I just read MosRoad's post and feel compelled to state that I'm referring to suburban to semi-rural type driveways where space is typically limited. I agree that in relatively wide open spaces plows on trucks are king, get around tight garage home spaces however and they are not. Typical airport snow removal is considered heavy equipment, parking lot stuff still are usually one-tons with salt spreaders and for the most part are a bull in a china shop deal for most residential situations.
I often have people call me in to clean up the mess the plow guys leave.
   / Pictures of your snow weapons #4,866
I've plowed with a tractor and I've plowed with a pickup truck, at the local airport, clearing roads, taxiways between T-hangers, and 4 acre square parking area.... there's no way a tractor is faster or better for plowing snow from roads, driveways and large areas than a good pickup truck with a good plow. At 20mph in a pickup truck, you can plow a mile long driveway down and back in about 6-7 minutes. Even if you have to do it 3-4 times a day, it's still faster than a tractor. I hated plowing with the tractor out there. Just hated it.
   / Pictures of your snow weapons #4,867
Well said my friend :thumbsup:
   / Pictures of your snow weapons #4,868
Well, there would have been no way I could have plowed this stuff, going through the woods!
   / Pictures of your snow weapons #4,869
I agree with you a plow would be useless in that situation.
Where about are you cause looks like my neck of the wood
   / Pictures of your snow weapons #4,870
I have mentioned before that I have a side x side with a plow that I use at the beginning of the Winter to lay out a base then the blower is use for the rest of the season unless we only get a few inches then the side x side comes out.
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
2003 Isuzu NPR-HD Truck, VIN # JALC4B14637000853 (A57453)
2003 Isuzu NPR-HD...
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
2025 Anvil 16 ft S/A Enclosed Trailer (A56859)
2025 Anvil 16 ft...
County Line Push Trimmer (A57454)
County Line Push...
9ft. EZ Loader S/A Boat Trailer (A56859)
9ft. EZ Loader S/A...
