Gate hinge rant
   / Gate hinge rant #11
randy41 - I mounted mine with both hinges pointing up. No need to "lock" the gate into the gate post. The weight of the gate keeps it there. Mine has been there for over 38 years and the neighbors cows haven't been able to lift it off the hinges yet.
Lord knows - they have sure tried. My 80 acres is the only "non-grazed" property within twenty miles and in the late summer the knee-high green grass really attracts them. They will stand at the gate and "beller" like they are in real pain.
ROBBYR - when my gate is closed - it rests on a cinder block at the gate post on the other side. It does not "free hang". This takes all the hanging force off the gate hinges. No pics of that situation - too much snow on that side of the gate.
   / Gate hinge rant #12
Self tapping screws don't have the power to hold. They will loosen, drop out and you will be right back where you are now.
Yeah....only had one that way 15 years now....I suppose another 15 or so, it will loosen and fall out.......
   / Gate hinge rant #13
I welded the gate hinge pieces to the gate itself. Top and bottom hinges. I had problems with people lifting the gate off the hinges.
I had a dog that got loose by doing that!. Fixed it by installing a lag screw jusst above the top hinge.
   / Gate hinge rant #14
I helped a neighbor get his herd back in. The cows did manage to lift the gate high enough
   / Gate hinge rant #15
Horses will lift the gate off easily. All of ours have the top one pointing down.
   / Gate hinge rant #16
Have quite a few gate makers in my neck of the woods. Some use a lower hinge without the flanges where the bolt goes through and weld it to the vertical pipe then rely on the adjustable top hinge for hanging the gate. Having horses, I too point the upper pin down.
   / Gate hinge rant
My yard gates I hung with both hinges facing up but I learned with the bull in the pasture the top hinge better face down. He did pick one up one time so I made sure to solve that problem. On a couple of gates I bolted a lawn mower wheel on unhinged end. Works great. Except when setting the last corner post I did not leave room for a wheel. Like the ideas about screw or bolt through bottom hinge.
   / Gate hinge rant #18
I've always hung bottom pin up and top one pointing down too. That's the way i learned it from my father. Also, on my gates, the socket side of the hing is a clamp arrangement around the gate pipe so it can be loosened or tightened so that it doesn't rotate around the pipe.
   / Gate hinge rant #19
Soooo....... if it's going to be a big concern - - just turn the top pin down. I guess my neighbor's cows just aren't into lifting gates.
   / Gate hinge rant
The top pin is turned down. The issue is with the bottom swiveling no matter how much I tightened it.
Clark G500-50 4450lbs Propane Forklift (A51691)
Clark G500-50...
Countyline Single Row Cultivator (A50123)
Countyline Single...
KMC KELLEY 3360 PEANUT COMBINE (A51247)
KMC KELLEY 3360...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
2025 Swict 84in Bucket Skid Steer Attachment (A51691)
2025 Swict 84in...
