Getting Serious About Buying My First Tractor......Which One?
   / Getting Serious About Buying My First Tractor......Which One? #1
RollTide1974
Member
Alabama, Alabama
None
I've been doing a lot of reading and watching videos lately. I am between a Mahindra 4540 or a Kubota MX5200 or L4701DT. My land as you can see from the aerial pic is about 95% pasture land. I have a couple of hills that I bush hog, the one pic gives you a general idea of one of the hills (the other hill is steeper). As of now, I do not have any animals on my land. I just bush hog it when needed, but am planning on eventually getting some animals (probably cows). We have roughly 26 acres, and the chance of us expanding that is slim to none. Just looking for any input from all you experienced folks. This will be my first tractor, and I am a city boy living on some land :).
What I like about the Mahindra is how heavy it is (5k). I have also been told it's a benefit that it doesn't have to ReGen. I know the dealer personally and he is stand up guy. I honestly don't think I'd have any issues with warranty work.
With the Kubota, I have heard great things about the reliability, and they have some great rates/package deals right now. The one thing and maybe the only thing I don't like on the Kubota is how light it is compared to the 4540.
Thoughts? Suggestions?
   / Getting Serious About Buying My First Tractor......Which One? #2
Weight is a benefit. Weight is traction. Weight is stability when lifting FEL and attachments.
How do FEL & 3 point hitch lift ratings compare?
Kubota is a good company and has had good products, but how can one speak of reliability when regen hasn't been around for very long?
:2cents:
   / Getting Serious About Buying My First Tractor......Which One? #3
Start with a list of the operations you want to do with the tractor. Then figure out the implements you'll need to do them. Then figure out the tractor you'll need to run the implements.
Many of us make spreadsheets to compare tractor models when shopping, to avoid having to flip back and forth from web site to web site.
   / Getting Serious About Buying My First Tractor......Which One? #4
I'll just leave that here. I can link more videos of the same tractor having issues.
   / Getting Serious About Buying My First Tractor......Which One? #5
Kubotas are the Honda or Toyota of tractors. Mahindra is the Kia of tractors. John Deere is the Chevy or Ford of tractors. LS and TYM are the Chrysler of tractors.
Shots fired!!
Coby-----I'm not sure on the 3 point hitch, but I believe the FEL the 4540 lifts about 700 more.
Eric----That's a great idea with the spreadsheet...thanks!
MadOne----I will watch the video, but I am assuming there are similar videos out there about Kubota.
   / Getting Serious About Buying My First Tractor......Which One? #7
You will get a lot of good info here; been operating tractors for over 60 years and still sought and benefited from some really good TBN members. We have flat lands as well as hills, so one tractor may be good at both or better on one than the other. Weight has been mentioned and it can help or hurt depending on terrain, job to do etc. Some of our tractors have no added weight, no fluid in tires while others have fluid filled tires and cast centers or weights. You can add weight easier than reduce. Good luck.
   / Getting Serious About Buying My First Tractor......Which One? #8
I'll just comment on weight. It can be both a good thing and a bad thing. The bad is it can rut the ground if it is a little bit soft. The good is it allows you to do more work faster, such as lift larger loads. You really need to tell us what you want to do with your tractor. Mow, move dirt, finish mow etc?
Dave----I would envision it being used mostly for bush hogging, working on the driveway, and potentially moving hay to feed livestock down the road.
   / Getting Serious About Buying My First Tractor......Which One? #10
My 2009 Kubota M6040 came to me weighing around 5200#. By adding the FEL & grapple - RimGuard loaded rear tires - HD Rhino rear blade - - I've kicked the weight up to 10,100#. What might have been considered a fairly light tractor is now, pretty much, a heavy weight tractor.
It was not the cheap way to go but everything I added was something I have needed/wanted anyhow.
Volvo ECR235CL (A53317)
Volvo ECR235CL...
2018 Ariens Ikon 52in Zero-Turn Commercial Mower (A56857)
2018 Ariens Ikon...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A56858)
2014 Ram 1500 4x4...
2005 Ford Escape (A56859)
2005 Ford Escape...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A54814)
2021 Ford F-150...
2013 Land Rover Range Rover Sport 4X4 SUV (A55853)
2013 Land Rover...
