1120 throttle friction disk issues
   / 1120 throttle friction disk issues #1
espacef1fan
Shopping for a tractor
My 1120’s throttle won’t hold its setting/position so I believe the friction disks are worn.
I don’t see any procedures for adjustment in the manual and new friction disks are $68. A PIECE!
Anyone have any other fixes or ideas I should/could try?
   / 1120 throttle friction disk issues #2
The hand throttle friction washers(key 6) that I see in 1120 PC are L41465 Washer ADD 3.73 USD 7.46 USD
The throttle linkage is challenging to disassemble but you're correct on needing to change friction washers.
   / 1120 throttle friction disk issues #3
Tx Jim
You think tightening down nut #3 against spring #7 wouldn't increase the friction enough to improve holding?
Looks like an adjustment possibility there..
Edit: see now that they are not nuts.. but called "grommets" in the parts list..so no adjustment possible.
Those “nuts” are bushings
And I was mistaken, the cheaper pieces are the friction disks according to the manual(which I reread after misreading)
   / 1120 throttle friction disk issues #5
Tx Jim
Only way to tighten is to install new friction washers or adding shim washer to increase spring pressure on worn friction washers.
I have new friction washers on the way. $3 ea.
Thanks for making me double check my work
   / 1120 throttle friction disk issues #7
You're welcome
Jim
The hand throttle friction washers(key 6) that I see in 1120 PC are L41465 WasherADD3.73 USD 7.46 USD
You weren’t kidding on it being annoying to disassemble.
I had to buy some new punches(lost mine in the move) but that was the biggest snag.
Next up on this beast is changing all the fluids/filters and new tie rods.
After that? Fixing the wiring/gauges/lights
2014 INTERNATIONAL MA025 BOX TRUCK (A53426)
2014 INTERNATIONAL...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
40' High Cube Multi-Door Container (A50123)
40' High Cube...
CATALOG UPDATES (A53084)
CATALOG UPDATES...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
2012 Hyundai Sonata Sedan (A51694)
2012 Hyundai...
