1120 throttle friction disk issues
   / 1120 throttle friction disk issues #1
espacef1fan
Shopping for a tractor
My 1120’s throttle won’t hold its setting/position so I believe the friction disks are worn.
I don’t see any procedures for adjustment in the manual and new friction disks are $68. A PIECE!
Anyone have any other fixes or ideas I should/could try?
   / 1120 throttle friction disk issues #2
The hand throttle friction washers(key 6) that I see in 1120 PC are L41465 Washer ADD 3.73 USD 7.46 USD
The throttle linkage is challenging to disassemble but you're correct on needing to change friction washers.
   / 1120 throttle friction disk issues #3
Tx Jim
You think tightening down nut #3 against spring #7 wouldn't increase the friction enough to improve holding?
Looks like an adjustment possibility there..
Edit: see now that they are not nuts.. but called "grommets" in the parts list..so no adjustment possible.
Those “nuts” are bushings
And I was mistaken, the cheaper pieces are the friction disks according to the manual(which I reread after misreading)
   / 1120 throttle friction disk issues #5
Tx Jim
Only way to tighten is to install new friction washers or adding shim washer to increase spring pressure on worn friction washers.
I have new friction washers on the way. $3 ea.
Thanks for making me double check my work
   / 1120 throttle friction disk issues #7
You're welcome
Jim
The hand throttle friction washers(key 6) that I see in 1120 PC are L41465 WasherADD3.73 USD 7.46 USD
You weren’t kidding on it being annoying to disassemble.
I had to buy some new punches(lost mine in the move) but that was the biggest snag.
Next up on this beast is changing all the fluids/filters and new tie rods.
After that? Fixing the wiring/gauges/lights
2016 RAM 3500 HD SERVICE BODY TRUCK (A53426)
2016 RAM 3500 HD...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A53473)
2020 Massey...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2021 Harley-Davidson FLHP Police Electra Glide Motorcycle (A51694)
2021...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
