Vmax540
Curious, why do tractors not have a radiator overflow tank ?   It is nice to check tank for coolant and condition of antifreeze.
The older tractors are just like the older pickups, trucks and cars the overflow from the radiator just went to ground.
When they started switching over to the coolant recovery tanks it was a bit more then just adding a tank.
Some of the radiators themselves required different necks and they all required a different radiator cap.
It not only needs to seal the bottom of the neck below the overflow port but also the top of the filler neck above the overflow and needs to allow the return of fluid when the system cools and starts to pull a vacuum on the system.
