Do you grease your hitch ball
   / Do you grease your hitch ball #2
Just wondering, my hitch ball is sort of rusty which I think is ok. But do you recommend putting a bit of grease on it to reduce wear and tear?
Your choice until your significant other ruins a $200 piece of clothing walking past it :)
Personally I have tried it and it doesn't seem to make any difference just a bigger mess. When pulling the trailer the rust wears off quickly, but I am only pulling loads of <6000LBs.
   / Do you grease your hitch ball #3
Nope. That will collect dirt like a magnet. Then you will have a greasy, dirty mess to clean off. You don't want the extra dirt/grit getting between your hitch coupler and hitch ball. Just no need for that kind of aggravation.
   / Do you grease your hitch ball #5
Not the ball, but I do shoot chain lube up into the coupling socket to keep the works freed up.
   / Do you grease your hitch ball #6
Yes put grease on the hitch ball and buy a cover to keep on the ball. Always make sure the ball has been greased before towing with it.
   / Do you grease your hitch ball #8
I agree. Lube the ball for less wear and ease of coupling. Cover when not in use. I don’t have a cover for my 2 5/16” ball so I just pull the drop out of the receiver and store in the truck cab.
Frank
   / Do you grease your hitch ball #9
I find that greasing the hitch is more important than greasing the ball. I make sure to use a piece of treated lumber to keep the hitch off the ground on trailers with no jack. The aerosol white grease works great. A shot of rattle can on the ball will keep it from rusting.
   / Do you grease your hitch ball #10
Have you ever seen a trailerball worn to the point of being unsafe?
I have trailer balls older then most of the people here and they are still servicable.
If anything wears out, it's the threads or the nut.
Kubota LX2620 (A53317)
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
Blue Diamond 103709 (A53317)
Blue Diamond...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2018 INTERNATIONAL...
2021 BMW 1200RT (A55853)
2021 BMW 1200RT...
