Do you grease your hitch ball
   / Do you grease your hitch ball #11
Have you ever seen a trailerball worn to the point of being unsafe?
I have trailer balls older then most of the people here and they are still servicable.
If anything wears out, it's the threads or the nut.
Nope....I have never seen a worn out trailer ball, but I have seen one that is somewhat worn.
A more important issue is the trailer coupler.
When/if that gets worn down (you cannot see under it easily), your coupler will fail, and the ball condition will not matter a bit.
Absolutely! You SHOULD grease your trailer ball....to protect the coupler!
And....what about the safety chains?
A VERY high percentage that I see are NOT crossed.
There is a very good reason for crossing them, but apparently MANY do not know!
   / Do you grease your hitch ball #12
Your choice until your significant other ruins a $200 piece of clothing walking past it :)
Personally I have tried it and it doesn't seem to make any difference just a bigger mess. When pulling the trailer the rust wears off quickly, but I am only pulling loads of <6000LBs.
Now Im sure we are po folks. I dont think my wife has a complete outfit that cost that much.
And ifn she did I know she wouldnt be anywhere near my old truck😀
   / Do you grease your hitch ball #13
Maybe if you wanted to clean it off when you’re done. Otherwise it’s a big mess that collects dirt.
   / Do you grease your hitch ball #14
Quote Originally Posted by fried1765
Should I grease my chains where they cross, to prevent wear?
:D
Bruce
   / Do you grease your hitch ball #15
Most of the chains I see are crossed, but almost dragging the road. No way they could catch a fallen tongue.
Bruce
   / Do you grease your hitch ball #16
Of course they will if crossed. If the trailer separates that will take that slack out.
Oh...and I do both....grease the ball and inside the coupler. Gojo hand cleaner as a laundry pretreat does great getting the grease stripe off the knee of your pants :)
   / Do you grease your hitch ball #17
I had a boat trailer with cable “chains” and a big sticker that said do not cross safety chains.
   / Do you grease your hitch ball #18
A friend and work associate of mine pulls a commercial chipper with an Isuzu arborist truck. We hitched and unhitched and pulled the chipper around constantly day in and day out. One day the chipper jumped the ball. Why? After many years of extended use the ball had shrunk and needed to be replaced. True story. After that, the precaution was to keep that ball and socket lubed up. It never happened again.
   / Do you grease your hitch ball #19
:D
Bruce
Nope Bruce!
You COULD grease your brake linings though.
They would last longer.
   / Do you grease your hitch ball #20
Bruce
Having the chains dragging is yet another often observed unstatisfactory trailer towing condition!
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A52748)
2000 Kenworth W900...
2018 CUMMINS CM20-1 PORTABLE SKID GENERATOR (A55745)
2018 CUMMINS...
2020 DRAGON ROLL OFF TRAILER (A55745)
2020 DRAGON ROLL...
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
2016 MACK CXU613 MID-ROOF SLEEPER (A55745)
2016 MACK CXU613...
2022 FORD F-250 XL SUPER DUTY (A55745)
2022 FORD F-250 XL...
