Today's Shop Time
   / Today's Shop Time #1
Larry Caldwell
Elite Member
Myrtle Creek, Oregon
Kubota l3130
I just paid $120 for a 50 year old Rockwell 17" drill press. The only thing wrong with it is the switch, and it's missing the nut that sets the depth stop. There are instructions for wiring the motor for 220v on the motor plate, and for reversing the motor, so that will happen soon. The bearings and chuck are good, with no detectable play in the spindle.
I'm thinking of wiring the motor to a wall switch that will let me reverse the motor and start/stop the tool. What do you guys think of that?
I also have a lathe vise with a bolt pattern that won't match up to the lathe work table, so have to figure out what to do about that. A piece of channel should make a quick and dirty adapter, but I'm open for more elegant suggestions. No, I'm not going to mill either the vise or lathe to make them match up.
   / Today's Shop Time #2
You know what's best for you, but I didn't have any of my tools hardwired, but I do have a lot of receptacles. I built all of my benches and work benches such that they fit the wall, but can be moved if necessary.
   / Today's Shop Time #3
No photos= It never happened!
   / Today's Shop Time
Good point. I could easily mount all the switching on the drillpress itself. A small electrical box with a couple of switches is all I would need. I'll have to look at the wiring for reversing rotation. It might need a QPDT switch. The idea of being able to back out a stuck bit appeals to me, though.
I just built a new shop, and am getting it set up like I like it. Like you, I made the benches movable. I have some leftover 6" screws that hold the trusses down, so used those to secure the benches to the wall. The work benches are in 8' sections, so I can rearrange them if I want. Taking a tip from my kitchen layout, I built a C-shaped 8x8 work area
I still have a steel bench to build that will be so heavy I think gravity will secure it. The top will be a 300 lb. L-shape hunk of 3/8 plate that I picked up at a scrap yard, the frame will be scrap angle iron and tubing, and the buzz box welder and high frequency injector will sit under the bench. I think the argon tank and regulator for the MIG torch will fit under there too.
   / Today's Shop Time #6
I can use my workbench as an outfeed table for my table saw; it's light and can move it anywhere...and my table saw is on wheels.
   / Today's Shop Time #7
I don't have a drill press, but have a 9x30 milling machine so use it in place of a drill press often. I would absolutely hate a wall switch to start/stop it. Mine has a 3-way switch. Center is off, left is forward, right is reverse. But it's right there and easy to reach. Taking a step to from a wall switch would be very irritating to me.
Not entirely sure what a lathe vise is or if it is for a wood lathe or an metal/engine lathe. My lathe is metal lathe. If you're talking about a cross slide vice or milling vise you attach to a lathe to use it as horizontal milling machine you should be able to drill & tap into the cross slide and mount that way. Kind of like how you'd mount a follow rest. Wouldn't be ultra rigid, but could do some light milling and would be fairly simple to get setup or taken down.
   / Today's Shop Time #8
My upload speed is 26 kbit. Yeah, I'm a little rural. I'll put something online when I go to bed tonight, and maybe the upload will be finished by morning.
No worries fun project
   / Today's Shop Time #9
Why would you ever want to reverse a drill press? As for the rest, the missing parts are probably available. Rockwell then Rockwell/Delta then just Delta (maybe missing that Rockwell/Milwaukee got married/divorced at some point also). Same machine for the most part (how can you improve on a basic machine like a drill press)?
2014 KENWORTH T680 (A52472)
2014 KENWORTH T680...
2014 Honda Accord Sedan (A50324)
2014 Honda Accord...
1267 (A50490)
1267 (A50490)
2019 Chevrolet Express (A50120)
2019 Chevrolet...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2011 New Holland Boomer 90 MFWD Utility Tractor (A52748)
2011 New Holland...
