I bought a 15K PTO generator. It was used and it had 1 hour run time on it.
   / I bought a 15K PTO generator. It was used and it had 1 hour run time on it. #1
Gofast
Gold Member
Greenville SC
MF GC 1725, 2016 MF GC 1710, Belarus 300
I will be using the 50-amp 12K plug that is about right for my tractor.
I should be able to run my welder off this.
I have been looking for a while and I finally was able to pick one up.
I have a 5K gas generator. I will tune it up and sell it. I will be nice not maintaining another gas engine.
I wounder what the run time will be on a tank of fuel.
   / I bought a 15K PTO generator. It was used and it had 1 hour run time on it. #2
That should work out very good for you!
I run my welder off my 15kw pto gen set quite often, I can't even tell it's on a generator.
SR
I made an offer on it Feb 2 they said they would just let is sit there and not sell it for that. I sent message back saying if you change your mind just let me know.
Today I got a message so I was able to get it for $700.
   / I bought a 15K PTO generator. It was used and it had 1 hour run time on it. #4
what brand is it?
   / I bought a 15K PTO generator. It was used and it had 1 hour run time on it. #6
You probably have already but if not check your gearbox oil SAE 90 . First change after break in period i think is 25 hrs .
That is first on the list to change the gear lube. It only has had one hour on it but that lube has to be old so I will just change it.
   / I bought a 15K PTO generator. It was used and it had 1 hour run time on it. #8
Does unused "lube" deteriorate while just sitting?
The manual says change 25 hours then every 250 hours or every 6 months.
I just want to start with known good lube and moisture could be in there from sitting so long. I don't know that SAE 90 is in there now.
I would not think it would go bad. Think how long gear lube sits in a trucks rear end and still works fine.
   / I bought a 15K PTO generator. It was used and it had 1 hour run time on it. #10
One thing I noticed in the pict. is, there's a toggle switch to go from 120V to 240V. Is that right?
I wouldn't like that at all, as when I'm welding, (240v) I like to be able to pick up my side grinder and use it. (120v) AND, if I have some help I may have them grinding as I weld. Also I may have lights also hooked to the gen set and they are 120v too. I wouldn't want to have to be switching back and forth between voltages...
There's no switch on mine, you can use any or all of it at the same time.
SR
54in Loader Fork Attachment (A59228)
54in Loader Fork...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2021 Chevrolet...
24in pin on excavator tooth bucket (A56438)
24in pin on...
2010 Ford F-550 4x4 Venturo HT40KX 3 Ton Crane Mechanics Truck (A59230)
2010 Ford F-550...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
2006 Columbia Medical Transport Electric Utility Cart (A56859)
2006 Columbia...
