Reconnect Hydraulic Line to Backhoe
   / Reconnect Hydraulic Line to Backhoe #1
Yuhong
Kubota L3301
I made a stupid mistake and am seeking advice.
Tractor: Kubota L3301, Backhoe: Kubota BH77. Almost new, only 23 hours.
I disconnected the backhoe to hook up the disc. While disconnecting the backhoe, I DID NOT RELEASE the pressure in the Hydraulic Line in backhoe. After using the disc, I tried to hook up the backhoe and the hydraulic line would not be able to be connected. After some discussion, we realized that there was some pressure trapped in the hydraulic line preventing the lines to be connected.
Right now the backhoe is still sitting on the ground. What would be the best and easiest method to release the pressure in the backhoe's hydraulic line? Then I can reconnect the backhoe to the tractor.
Thank you all very much.
Digou (408-688-4299 - cell)
   / Reconnect Hydraulic Line to Backhoe #2
In general BH have the controls with the implement so it isn’t attached to the machine. If that’s the case you will need to brace the BH (so it doesn’t fall over or something) and run the valves in all directions to relieve the pressure. If the machine doesn’t have a valve to the BH QDs you will also need to make sure the machine is off so the machine side QDs don’t have pressure. If the machine does have a valve, turn the machine off and cycle the valve to relieve pressure.
If I’m thinking about this wrong then you will need to push in on the middle of the male QD. This can be easier said than done without the little tool. But with some thinking you can get it done without the tool.
Dave's Delights Hydraulic Hose Pressure Relief - YouTube
   / Reconnect Hydraulic Line to Backhoe #3
You can also start to unscrew the hose from the coupler until it starts to leak and then just let it leak for a little while. It does not take much fluid to be released to drop the pressure as the hydraulic oil is in-compressible unlike air.
However, the backhoe either needs to be collapsed as much as it physically can or supported so you are not waiting for a cylinder(s) to reach the end of their strokes..
A block of wood and a heavy hammer. Strike the exposed ball with the wood protecting the ball. Fluid will be released. May take a few strikes.
Remember, the fuid being released is under high pressure so eye protection and gloves.
Dave M7040
   / Reconnect Hydraulic Line to Backhoe #4
Most likely the problem is not that you didn't relieve pressure in it before disconnecting, it's the backhoe settling on it's cylinders. I've had that happen. I block it up when I take it off so that the backhoe is not putting weight on the dipper or outriggers and the bucket's on the ground.
You can release pressure on the male connector end by gently striking the tip with something. If it's a nipple instead of a ball at the tip (as is common with OEM couplers these days) I'd recommend unscrewing the connector from the hose. If it's the female connector on the backhoe that won't allow you to connect you have to unscrew it. Yea you could stick a screwdriver in there and hit it with a hammer but that seems too likely to damage something. The pressure in the hoses will be a few hundred psi not thousands like when it's operating.
When I take the backhoe off I connect its connectors together. It keeps them clean and out of the way and with both sides connected it's less likely to develop pressure (but it can still happen).
That should be it: "Most likely the problem is not that you didn't relieve pressure in it before disconnecting, it's the backhoe settling on it's cylinders. " When I stationed it. The backhoe arm was not in its mots collapsed stage. I will try to support the entire backhoe so the backhoe is not settling on it's cylinders. This may make the backhoe not putting weight on the dipper or outriggers. So, the pressure will be released. Then I will try to connect them again.
Meantime, I will do some research on Kubota BH 77 to see if I can do this: "If the machine does have a valve, turn the machine off and cycle the valve to relieve pressure. "
All these are very sound advise. What would be the best for me to do if I need to disconnect the backhoe again (Which I will do often)? I only have one tractor and I need it to work on disc harrow, plow, box scraper, and other implements, plus the backhoe. Maybe it is time to ask wife for another tractor? Better not.
Thank you all so much.
Digou
PS. I will try to post pictures if I did it successfully. (can we pos picture here?)
   / Reconnect Hydraulic Line to Backhoe #6
For any impliment...
Put supporting material under it if needed and/or set it on level ground.
Put the machine in park.
Turn the machine off.
Work all the valves so there is no pressure on any cylinders or on the machine.
Disconnect the hoses & unhitch the impliment.
If you do that when the fluid is cold & later hitch up on a warm day, you can still have issues due to the fluid heating up & expanding. But the above steps will give you the best chances to avoid issues.
   / Reconnect Hydraulic Line to Backhoe #7
Digou
Out riggers down, bucket on the ground and thumb against the bucket. Then turn the machine off and run all the levers until their is no more movement of anything on the BH. Then unplug the hydraulics to the BH.
   / Reconnect Hydraulic Line to Backhoe #8
In general BH have the controls with the implement so it isn稚 attached to the machine. If that痴 the case you will need to brace the BH (so it doesn稚 fall over or something) and run the valves in all directions to relieve the pressure. If the machine doesn稚 have a valve to the BH QDs you will also need to make sure the machine is off so the machine side QDs don稚 have pressure. If the machine does have a valve, turn the machine off and cycle the valve to relieve pressure.
If I知 thinking about this wrong then you will need to push in on the middle of the male QD. This can be easier said than done without the little tool. But with some thinking you can get it done without the tool.
Thanks for the link! Today was so nice I got the utv and went for a spin and visited a neighbor one mile away and he had just removed his front snowblower and subframe on his fairly new Kubota 35 hp cab and was trying to install the loader and couldnt push them on. I determined the tractor side had no pressure but the loader side did. We tried to push the center pin with no avail. I suggested loosening two fittings on the loader frame. When he loosened I was able to install the lines.
I had a similar experience with my backhoe.
Time to make two of these tools!
Thanks to Dave on YouTube too!
   / Reconnect Hydraulic Line to Backhoe #9
I connect a home made manifold to the hoses of my backhoe and other hydraulic implements when not in use.
Any pressure buildup is easily eliminated by opening the valve. The expelled oil is easy to collect without making a mess.
   / Reconnect Hydraulic Line to Backhoe #10
As others have mentioned, just whack the [covered with a cloth] ball on the QR fitting to relieve the pressure. I actually made a little device out of a gear puller that grabs the outside of the fitting and easily presses the ball (or whatever kind of valve it has.) I often change stuff on my tractor, front and rear, and the only time I don't need to bleed is if I remove something in the heat of the day and reinstall it when it's cool.
2020 DRAGON ESP...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A56438)
Michelin CARGOXBIB...
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
2022 LEEBOY 8520B ASPHALT PAVER (A60429)
2022 LEEBOY 8520B...
2016 Textron T/A 15 Ton Flatbed Equipment Trailer (A59230)
2016 Textron T/A...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A56438)
LMC 2-Row Planter...
