Can a Kubota L3301 run a 6 foot Land Pride rotary cutter?
   / Can a Kubota L3301 run a 6 foot Land Pride rotary cutter? #1
ScapulaFarm
None
Dealer says I should stay at 5 foot width but I壇 like to get more efficient cutting done if I can. Only mowing tall weeds, some grass, no saplings, smooth field with mild grade, 10 acres.
   / Can a Kubota L3301 run a 6 foot Land Pride rotary cutter? #2
Is this a rough cut or finishing mower? I have a B2710 and run a five foot rough cut mower or as we call them a "bush hog" and it handles that fine. There is good bit of weight jump I think from it to a 6 foot rough cut mower. If rough cut think you would want or need front weights. My B2710 does have front weights on it.
On finish mower run a 6 foot on it, rear finish mower. Unless in real heavy grass handles it fine.
   / Can a Kubota L3301 run a 6 foot Land Pride rotary cutter? #3
Like kthompson said, a lot of your tractors ability to operate a 6 footer depends on the weight of the implement. I run a 6ft. brush mower with a 27 horse tractor, but I only cut areas that have been previously mowed. (pasture clipping) I have found that about a half a bucket of dirt in the FEL helps the steering and stability a lot. Another thing to remember is a 6 ft. rotary is lots longer as well, so less maneuverability around fence posts and trees. I find that out more often than I care to admit. In reality, I don't think that extra foot of cut speeds things up that much, so when and if I get another one, I would buy a 5 ft. just because I believe the larger one creates a lot of extra stress on a smaller tractor...…..Dan
   / Can a Kubota L3301 run a 6 foot Land Pride rotary cutter? #4
Like kthompson said, a lot of your tractors ability to operate a 6 footer depends on the weight of the implement. I run a 6ft. brush mower with a 27 horse tractor, but I only cut areas that have been previously mowed. (pasture clipping) I have found that about a half a bucket of dirt in the FEL helps the steering and stability a lot. Another thing to remember is a 6 ft. rotary is lots longer as well, so less maneuverability around fence posts and trees. I find that out more often than I care to admit. In reality, I don't think that extra foot of cut speeds things up that much, so when and if I get another one, I would buy a 5 ft. just because I believe the larger one creates a lot of extra stress on a smaller tractor...?.Dan
I agree. I ran a 5ft on my 45hp tractor and it seemed to be about right.. I think a 6ft would have made me slow down, what would I have gained other than weight and less maneuverability.
   / Can a Kubota L3301 run a 6 foot Land Pride rotary cutter? #5
I ran a 5' land pride finishing mower on my L2501 quite easily
   / Can a Kubota L3301 run a 6 foot Land Pride rotary cutter? #6
Maybe stay with a 5' mower. I'm running a 6' on mine, but I have 32 pto hp. I have no problems with it at all, even 6' tall weeds. I also leave my FEL and bucket on when I'm mowing, so no need for additional front weights.
   / Can a Kubota L3301 run a 6 foot Land Pride rotary cutter? #7
I went to a 6 ft with my new 2538 and was surprised how much faster i was able to mow the same area over the 5 ft. I think going to hst over my other shuttle shift tractor was also faster.
   / Can a Kubota L3301 run a 6 foot Land Pride rotary cutter? #8
My '63 Ford 2000 is currently connected to a Kodiac Med. Duty, 6'. Works just fine and in fields where crop density varies, if I get into heavy stuff and the tractor starts asking for help....pretty dense usually wet stuff, I just move over, cutting less till it likes it and go on about my business.
   / Can a Kubota L3301 run a 6 foot Land Pride rotary cutter? #9
I have 1000+ hours on a 5'Bush Hog branded medium duty mower on three different tractors 30-44 HP;the smaller tractors were a good fit for this mower.
I purchased a LandPride 6' for the larger tractor;good fit for that machine.Only slow down was in 6-7' extra thick canary grass.
   / Can a Kubota L3301 run a 6 foot Land Pride rotary cutter? #10
Here ya go. A 6 foot cutter is only a 6 foot cutter while making the first pass. After that it can be whatever width you need, up to 6 feet.
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2004 GREAT DANE 53FT REEFER TRAILER (A52141)
2004 GREAT DANE...
2013 John Deere 4730 Self-Propelled Sprayer (A51039)
2013 John Deere...
2014 John Deere 8360R MFWD Tractor (A50657)
2014 John Deere...
UNUSED CFG Industrial QK18R Mini Excavator (A47384)
UNUSED CFG...
2022 Ram Bighorn 2500 4X4 (A52128)
2022 Ram Bighorn...
