3rd function valve comparison
   / 3rd function valve comparison #1
Steve 3650
Member
EAST CENTRAL IOWA
Mahindra 3650HST
I am planning to install a 3rd function kit on a Mahindra 3650hst. I have read different threads here on the subject and have looked at different kits. All but one have used the same type solenoid valve [DO3] that requires a manifold. Summit Hydraulics offers a solenoid operated monoblock valve that is one piece and looks like it might take up less space. Summit claims there valve " can be used for continuous operation without failing unlike kits that use cheaper DO3 valves". Does anyone know about these and is one a better choice than the other?
Thanks,
Steve
   / 3rd function valve comparison #2
I’ve never used a Summit Valve. A good DO3 is rated for continuous use. Hyvar and I assume others are fine if properly sized. Based on what you have said I don’t see any reasons to avoid the Summit valve if that meets your needs.
   / 3rd function valve comparison #3
The subplate lets you replace the valve without removing all the hoses, if you need to.
If you're putting the valve in the circuit between the loader valve and the 3pt it probably should have an output port that can handle full system pressure. Some valves can only handle ~300 psi and operating the downstream valve can damage them.
   / 3rd function valve comparison #4
I'm looking at the same DO3 valve myself. The advantage of the diverter valve over most of the true 3rd function solenoid valves is that you can feather the hydraulics and pick up delicate things like pipe without crushing them. The third function solenoid valves I've seen (a solenoid on each side of the block) only have open/close.
   / 3rd function valve comparison #5
I used this type of valve. It is like an A or B switch. What ever circuit is getting hydraulic power, you have complete control over that circuit.
Inexpensive but has been reliable.
Hydraulic solenoid operated selector diverter valve 12 volt DC | eBay
Make certain when buying you know the type of ports it has.
If it is BSP then better to order adapters when you order the valve rather than trying to find BSP fittings locally.
It may not have BSP but SAE but check.
Dave
Thanks for the input guys, I don't think that I made my question clear.
I understand the difference between using a diverter valve and a true 3rd function valve. Both valves I mentioned are true 3rd function.
I am looking for a comparison between a DO3 valve and the Summit Hydraulics valve that I tried to create a link to below. What would be the pros or cons if any between them?
In all of the reading I have done on the subject, a DO3 valve was always used. So when I found a kit from Summit Hydraulics, that used a different valve, that they claim to be superior I am hoping someone can explain the difference. And possibly prevent me from making an expensive mistake.
Sorry but the forum won't allow me to show a link. I have about zero experience doing this so for now the best I can do is ask that you google summit hydraulic monoblock solenoid valve to see exactly what I am talking about.
Sorry again, Thanks for your help
Steve
   / 3rd function valve comparison #7
My bad, I understand now.
I don't have experience with either but I researched both and saw very few if any pros/cons to either. The one negative I did read about the DO3 came from a southern state and they were having issues with moisture getting into the hydraulics between the valve and the base of the DO3. Another con for the DO3, in my opinion, is the whole base mounting system. Seems like a PITA to find a secure, flat, accessible, and protected spot to mount it. The Summit seems easier to make it fit but that's just my opinion.
I just ordered the Summit diverter a few minutes ago, spoke to some of the folks there, seems like pretty good customer service.
   / 3rd function valve comparison #8
I'm currently running my grapple off a rear remote. I find that at least for my dual lid grapple on my tractor, I have no need to feather the grapple. I just push the lever all the way. The lids apply force slowly enough that I can stop when the grapple's gripping hard enough. Since mine's a dual lid it's got two decent size cylinders. A single lid with one cylinder would operate twice as fast.
   / 3rd function valve comparison #9
Just an FYI / word of caution. From my conversations with the folks at WR Long, their valves can be used for continuous operation as well BUT the risk isn't to the valve, it's to the tractor. Continuously flowing the fluid through a restricted orifice like a 3rd function, which is typically only a 3/8" hose vs a 1/2" hose for a rear remote, can cause excessive heat to build up in the fluid and damage the hydraulic system including seals and worse if your HST shares the same fluid reservoir.
You don't generally operate a 3rd function continously when using a plow or grapple so the restrictions aren't usually an issue.
Thanks everyone for your time and opinions.
It's tough for me to make a decision for something like this. I want to get it right the first time!
I just couldn't come up with a reason not to so I guess I'll have to get the Summit Hydraulics 3rd function kit on order.
thanks again,
Steve
FAKE (A52472)
FAKE (A52472)
UNUSED TOPCAT SSSCR72-72" HYD SOIL CONDITIONER (A51248)
UNUSED TOPCAT...
Unused Delta Crash...
1995 Generac 94A05603S Diesel Generator (A51691)
1995 Generac...
10" Shaver Post Driver (A52384)
10" Shaver Post...
UNIVERSAL WOLVERINE PFF2-13-45W QUICK ATTACH MAST (A51248)
UNIVERSAL...
