3 pt hitch lowering knob stuck
   / 3 pt hitch lowering knob stuck #1
dlabrie
Gold Member
Campton, NH
Kubota B2910
I went to loosen up my 3pt hitch lowering pressure and I couldn't turn the knob. I ended up using a pipe wrench to turn it. Is there a way to free it up?
Thanks
B2910 hsd
   / 3 pt hitch lowering knob stuck #2
is there a lock nut on the shaft"?
I don't know. The knob connects to a shaft that goes through the frame of the tractor. I haven't had any problem with it in 18 years of use.
   / 3 pt hitch lowering knob stuck #4
I had to do this on a tractor I bought. First, make really sure what way it needs to go. On mine, the 3 point dropped really fast, so I knew it was fully open. I used a pair of channelocks on the upper part of the thread just below the knob and my hand on the knob. I moved it clockwise to close. It moved right away and was easy from then on...was jammed fully open. Works good now.
Good Luck
Good Luck
I was able to move it with a pipe wrench but it didn't loosen up any. Maybe I need to work it some more,
   / 3 pt hitch lowering knob stuck #6
Squirt some lube down around the shaft and let it sit for a while. The knob on my L3200 had seized up after I hadn't used it in a long time and I couldn't turn it in either direction. I soaked it with some lube and tried again a few days later and was able to turn it by hand.
Thanks, I'll give that a shot.
72" General Purpose Skid Steer Bucket, S/N 103581 (A59076)
72" General...
2015 JOHN DEERE 35G EXCAVATOR (A52709)
2015 JOHN DEERE...
23013 (A55787)
23013 (A55787)
Terms & Conditions of Auction (Payment Terms) (A59213)
Terms & Conditions...
2022 Ram 2500 4x4 Crew Cab Pickup Truck (A55973)
2022 Ram 2500 4x4...
LOT OF FIRE EXTINGUISHERS (A58374)
LOT OF FIRE...
