Mud Season is almost done?
/ Mud Season is almost done? #1
cdaigle430
Maine
MF GC2410
Time to take the Berco cab, Woodmaxx snowblower, tire chains and Loader edgers off :) This year will do a complete tune up including hydraulics-maybe even a new battery. Im still on the original and unless I keep the trickle charger on it can barely turn the motor on a warm day. Battery is 9 years old though...
The new gear assemble for the TAC worked perfect in the cooooold days.
Battery recommendations? OEM, interstate or? Need a good one for cold Maine winters and the added LED lights, plus the cab heater, deflector and chute motors.
/ Mud Season is almost done? #2
Hey cdaigle430,
I know what you mean about mud season, my tractor usually sits in the garage when the ice starts coming off of the driveway in early April until late May or early June, because I do not want muddy ruts throughout the property.
Here is a link to the battery I purchased before last winter: Duracell Ultra Battery for BCI Group 51 SLI - SLI51 at Batteries Plus Bulbs
I was worried that during a long snow storm last winter that my old OEM tractor battery would die, only because it's about 10 years old.
I looked for an OEM battery replacement, but was unsuccessful. The original battery was still doing the job, but I noticed the cranking to start the tractor was a little bit slower in the colder temperatures before winter.
F.Y.I. I kept the OEM battery in the garage all winter long sitting without any charger hooked up to it and the glass window still is showing "green", I will have the battery tested before I turn it in for a core to see at what percent life it's at.
KC
/ Mud Season is almost done? #3
I'm figuring least month before adventuring off the hard surfaces,seems to be lot water in the ground this year.
/ Mud Season is almost done? #4
My wet areas remained too wet for tractor travel all last year and with the rain so far this Season it will be at least a month before I travel far from the gravel driveway probably two.
/ Mud Season is almost done? #5
We have gotten three inches of rain in Northern NY the last couple days;three weeks away from doing any work in the fields.Have a new pole barn to build ,so ready for dry weather.
/ Mud Season is almost done? #6
For sure. Another two weeks and I will be complaining about all the dust from my driveway.
/ Mud Season is almost done? #7
We’d dry up if it STOPPED raining already! :duh: I have a garage waiting to be built.
/ Mud Season is almost done? #8
Mud season is at full strength right here right now, the good news is I wont need a Ark. I seen lot of Aprils where forest fire danger is high, just not this year and not tonight or tomorrow or rest of the month. Weather man said it's guaranteed to dry out by August, September at the latest.
Johnny Cash "How High is The Water Momma" - YouTube
/ Mud Season is almost done? #9
Yes, here in the Great Northeast (OK, a bit over the top, I know) the frost went WAY deep due to all the $#@$ freeze-thaw cycles we experienced this winter. Still waiting for our dirt road to dry out, though it's better than it was a week or two ago. My snowblower's staying on for a while yet!
/ Mud Season is almost done? #10
If the rain doesn't cease (for a few weeks), mud season might go into June...
/ Mud Season is almost done? #11
cdaigle430 - I replaced the battery on my M6040 last year. Got an Odyssey group 31. 1150 CCA. A lot of battery but with the Deltron attached - never worry about winter starts. The OEM is still in use around the property. After nine years I get a bit nervous about an old battery.
I like to think I'm proactive.
/ Mud Season is almost done? #12
Yep...end of June we start losing day and before you know it leaves will change etc.etc. but there always next year as they say. ;)
/ Mud Season is almost done? #13
Hey, Roy & Thomas -- good to hear from you fellow med-season sufferers!
/ Mud Season is almost done? #14
Good to see your still making dust on the other side of the hill. :thumbsup:
Notice your road still posted due to the mud also some drivers can't read :(
Haven't seen you fly over our house this year. :confused3:
/ Mud Season is almost done? #15
I know I've said this for the past 4 years, but the plane's almost done.... Last area is the firewall forward. No surprise, discovered some stuff that wasn't right in that area, too. Hoping she'll be back in the air this spring/summer. DSC07303.jpgDSC07305.jpg
/ Mud Season is almost done? #16
A 1150 CCA battery won't last long in a tractor. To reach that capacity, the plates are placed very tight together. With all the vibration in a tractor, they will touch each other and short out.
Stay with the capacity the tractor came with.
/ Mud Season is almost done? #17
I live on a paved road (Route 12), but my field is a swamp right now...at least the mowing season (on the field) will be shorter this year!
/ Mud Season is almost done? #18
I walked my lower field this AM and still have running surface water. This week's NE weather will not be conducive to any drying.
It will probably be a nasty Blackfly Season this year.
/ Mud Season is almost done? #19
I just may get my chores done in the next week or so. I got started early but worked around and between the rain and the mud. I just have two trellises to build for the grapes and raspberries then done with the projects this year.
/ Mud Season is almost done? #20
Our antique tractor club in southern KS was going to have a plow day this weekend in field that was too wet to plow last fall. Now we have had 2 more days of rain and have to cancel because its still too wet. Rain date is next weekend according to the weather map that date will likely get rained out as well.
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56859)
2008 Ford F-250...
UNUSED FUTURE MINI EXCAVATOR GRAPPLE (A60432)
UNUSED FUTURE MINI...
UNUSED IRANCH 22" MINI EXCAVATOR BUCKET (A60432)
UNUSED IRANCH 22"...
2016 JOHN DEERE 135G (A58214)
2016 JOHN DEERE...
2012 TEX MEX TRAILER LOW BOY GOOSENECK (A58214)
2012 TEX MEX...
