2006 RTV 900 starts hard when less that 1/2 tank of fuel
   / 2006 RTV 900 starts hard when less that 1/2 tank of fuel
Lift pump. I have seen this problem many times. Good Luck Lance
Put on a $10 electric fuel pump from amazon and it runs like it hasn't in a long time. Also while I was at it I turned up the fuel on the injection pump 2 turns so now isn't quite so doggy and will roll a little black if I want it to. Thanks everyone again. Next project is to adjust the hydrostat so If you get stuck on a hill you can still get it out of gear. Doesn't seem to be getting completely to neutral at idle.
   / 2006 RTV 900 starts hard when less that 1/2 tank of fuel #12
   / 2006 RTV 900 starts hard when less that 1/2 tank of fuel #13
Glad you figured it out.
The HST issue is a tough one. There are some adjustments that can be made to make it easier to get out of gear. The most effective is patience. Hold the brake pedal down, wait 2 seconds, then try to get it out of gear.
Do you have a Shop Manual?
Ya that seems to work sometimes but there are other times on a steep grade where I have had to shut the engine down to get it out of gear. I don't have a physical shop manual but do have some PDF pages on it. Nothing about adjusting the shift cables that I have found yet.
Big Tex T/A Flatbed Trailer (A56857)
Big Tex T/A...
2010 Dodge Ram 4x4 Crew Cab Pickup Truck (A59230)
2010 Dodge Ram 4x4...
2020 ISUZU NQR BOX TRUCK (A58214)
2020 ISUZU NQR BOX...
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
2018 KOMATSU WA270-8 WHEEL LOADER (A60429)
2018 KOMATSU...
2024 Bintelli ActivEV Pulse Electric Cart (A59231)
2024 Bintelli...
