JD 301A s/a 1020. How to test hydraulic pump
   / JD 301A s/a 1020. How to test hydraulic pump #1
Mean Jean
Gold Member
Hazelridge, MB
Kubota L1801 and Massey 65
I want to test my hydraulic pump using a gauge.
Where do I plumb it in?
The manual is not helpful at all.
的nstall a hydraulic test unit or pressure gauge and start the engine to pressurize the system
   / JD 301A s/a 1020. How to test hydraulic pump #2
Mean Jean
I made a test gauge using a quick connector, short hyd. hose and the pressure gauge. Just couple it into one of the hyd. connectors. (if that is what you are asking).
The pressure gauge with male connector
Mean Jean
How do I “load” the hydraulics?
   / JD 301A s/a 1020. How to test hydraulic pump #4
Connect a gauge and work the hyd. valve , I'd think.
The only way I can add a load is by lifting new them 3 point hitch.
I haven’t t got a loader and the 2 auxiliary lines do not have a selector.
I found a pic of the hydraulic system. I am able to narrow down the high pressure line. I will need a T fitting.
I think I’m making headway.
   / JD 301A s/a 1020. How to test hydraulic pump #7
Besides installing gauge in hyd pump as shown in photo you could disconnect power steering supply line(key 4) & attach gauge to that fitting with a swivel connector. Female swivel thread size is 0.562 IN
Heck yeah!
I have the proper fittings at the power steering line.
   / JD 301A s/a 1020. How to test hydraulic pump #9
This type hyd check will not be correct way to monitor stand-by pressure on a 1020/300 prior to serial # 45,200 because those models have open center power steering with a pump mounted on RH frt of engine.
Thanks very much for the tip. Will check the serial # tonight.
Booster Cables (A59230)
Booster Cables...
McFarlane 4025 Reel Disk (A59814)
McFarlane 4025...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A58214)
WHISPERWATT 220...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A56438)
Midwestern...
UNUSED KJ 11' X 19' ALL - STEEL CARPORT (A52706)
UNUSED KJ 11' X...
2014 Lamar Trailer (A55973)
2014 Lamar Trailer...
