kthompson
Elite Member
- Joined
- Sep 12, 2008
- Messages
- 3,526
- Location
- South Carolina
- Tractor
- Kubotas B2710, M6800, L6060 cab, Volvo EC excavator, 2 ZTRs and various implements.
I have been looking at different brands of lawn power tools such as pole saw and hedge trimmer. Have looked at Stihl, Husky, Red Max and one or two other brands in person and more on line. Interesting how some seem to hold they only have professional grade products. Think there was at least two who held that position one being Red Max and then in their brochure they have Home Owner grade riding mowers. O well so much for professional grade only products. Know Stihl is help up at very fine professional grade products but they are very honest they have both professional and Homeowner grade tools. Then there are brands that seem to be offering only homeowner grade brands, lest just say to me most sold at big box stores fall into that class as least to me.
Found it interesting how much when you are comparing the true Pro Grade power heads or hedge trimmer or such from brand to brand the specs vary very little.When you compared the Homeowner grade they varied little from brand to brand in specs.
That got me to thinking on a topic that is often argued here and yes I know there will be those who will not agree with me but think on it honestly and open minded if you will. There are true Pro Grade tractors and there are Home Owner Grade tractors. When you compare specs across the Pro Grade tractors they are very much alike. Same with the Home Owner grade tractors. As with lawn equipment Pro and HO grades have most if not all options and offer about same features and hp. True Pro grade in lawn equipment can offer little higher HP.
Sticking with string trimmer for this over the years first owned a Weed Eater brand. They were the first brand I ever knew of and was it a true home owner grade or less in capacity. Then replaced it with a Green Machine with handle bars and it was a true Pro trimmer with all the capacity and quality the Weed Eater did not have. No idea the brand that replaced the Green Machine with but since then have Roybi and Stihl which both are Home Owner grade. The Roybi has the options of pole saw and edger and such. However they neither have the torque you would expect a Pro model would have. But either one can do the same job as a Pro model just not as easy or the same load as long.
Think you will realize tractors today are much like this. Some brands have both, while other brands may only offer the Pro or Homeowner version. I realize some will totally disagree with me and that is fine but it is easy to realize all tractors are not of the same grade. That does not mean the Home Owner grade is junk or trash, it just is not made for hour after hour load the Pro Grade is made to handle or maybe the shock loads or such. As with lawn equipment we none expect the Homeowner grade to equal the Pro grade and we certainly do not expect it to cost as much. Yet when people compare tractors they seem to miss all are not the same. HP or any one spec is not the way to truly compare. It has been said here how weight is so important in such as tillage and pulling. If you will just look back a few years the major tillage tractors went for weight maybe more so than HP. Don't think speed was even considered for any tractor was as fast or faster than a team of horses or mules.
