MfF 65 3 pt hitch
   / MfF 65 3 pt hitch #1
fatb
Member
Massey Ferguson 65 Gas
New to tractoring and recently bought a new old tractor '58 mf 65, just wondering if I need to add a top link bracket/beam to use top link and do i need to buy a braket for chain stays for control arms?
   / MfF 65 3 pt hitch #2
At the bottom red circle it appears that pin is in backwards. Face it the other way.
The red circle on the left. You may be able to fit a pin in there and then use an arm similar to a top link to connect the 2.
That will adjust your control arms.
My Massey came with a bracket that attached to the bolts in the left circle. That is there my control arm connects.
Can add a picture this evening.
As for the top blue circle.
If you can fit the end of a top link in there you can use your top link as is.
   / MfF 65 3 pt hitch
I just bought some check chains, check chain brackets, and control beam. I will also purchase a top link. thanks for the info
   / MfF 65 3 pt hitch #4
Attached (hopefully) 08128FE4-BBFB-4022-AFE7-BB58658BC3BB.jpeg1106F72C-2C2E-42E8-AA9C-459211691CC3.jpegare h08128FE4-BBFB-4022-AFE7-BB58658BC3BB.jpeg1106F72C-2C2E-42E8-AA9C-459211691CC3.jpeg
   / MfF 65 3 pt hitch
oh ok those are stabilizer bars right?
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
John Deere 5115M (A50120)
John Deere 5115M...
Toro Reelmaster 3100D Reel Mower (A50121)
Toro Reelmaster...
1993 INTERNATIONAL 9700 TANDEM AXLE CAB OVER (A52577)
1993 INTERNATIONAL...
2015 Ford Fusion Sedan (A50324)
2015 Ford Fusion...
