MfF 65 3 pt hitch
   / MfF 65 3 pt hitch #1
fatb
Member
Massey Ferguson 65 Gas
New to tractoring and recently bought a new old tractor '58 mf 65, just wondering if I need to add a top link bracket/beam to use top link and do i need to buy a braket for chain stays for control arms?
   / MfF 65 3 pt hitch #2
At the bottom red circle it appears that pin is in backwards. Face it the other way.
The red circle on the left. You may be able to fit a pin in there and then use an arm similar to a top link to connect the 2.
That will adjust your control arms.
My Massey came with a bracket that attached to the bolts in the left circle. That is there my control arm connects.
Can add a picture this evening.
As for the top blue circle.
If you can fit the end of a top link in there you can use your top link as is.
   / MfF 65 3 pt hitch
I just bought some check chains, check chain brackets, and control beam. I will also purchase a top link. thanks for the info
   / MfF 65 3 pt hitch #4
Attached (hopefully) 08128FE4-BBFB-4022-AFE7-BB58658BC3BB.jpeg1106F72C-2C2E-42E8-AA9C-459211691CC3.jpegare h08128FE4-BBFB-4022-AFE7-BB58658BC3BB.jpeg1106F72C-2C2E-42E8-AA9C-459211691CC3.jpeg
   / MfF 65 3 pt hitch
oh ok those are stabilizer bars right?
MAHINDRA MAX 24 HST COMPACT UTILITY TRACTOR WITH LOADER (A52748)
MAHINDRA MAX 24...
2018 Nissan Versa Sedan (A50324)
2018 Nissan Versa...
2007 STERLING L9500 TANDEM AXLE DAY CAB (A52141)
2007 STERLING...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2020 Chevrolet Express (A50120)
2020 Chevrolet...
Kent KHB3G Q.A Hydraulic Breaker (A50121)
Kent KHB3G Q.A...
