Perkins? 4 cyl turbo diesel identification help needed w/pics
   / Perkins? 4 cyl turbo diesel identification help needed w/pics #1
crawsfire
rhino
Hello,
I believe this is a perkins engine. There is HA stamped on the LH front side of the block. Can anyone ID this engine? Thanks!
   / Perkins? 4 cyl turbo diesel identification help needed w/pics #2
On the side of the injection pump where its been cleaned off/not painted over.. is a set of #'s..
Its either a Bosch or Zexel pump, cant tell from here.. just search the #'s on/off the pump & it'll tell u what u got..{engine}
Bosch will start out like> 0 460 *** *** {10 digit part #}
That was one of the things I tried with no success. The number is 104640-0220. thanks
   / Perkins? 4 cyl turbo diesel identification help needed w/pics #4
Dont think they had a HA family code. What piece of equipment is this engine in?
If its a Perkins, “the first letters of the engine serial number represent your engine family and type code. These can be found on the engine data plate, or on your sales order acknowledgment.”
Operation and maintenance manuals | Perkins Engines
If its a Perkins, 鍍he first letters of the engine serial number represent your engine family and type code. These can be found on the engine data plate, or on your sales order acknowledgment.
It's a Generac 30KW genset surplus from a Navy Base. No tags on the engine and no luck searching the NSN. I'm leaning towards an Isuzu. Sure wish I could figure it out.
   / Perkins? 4 cyl turbo diesel identification help needed w/pics #6
Try looking on the block around the starter/exhaust manifold
   / Perkins? 4 cyl turbo diesel identification help needed w/pics #7
Ahhh,, those # are Zexel #'s..
It's a Mazda HA 3.0 diesel licensed by Perkins (same as the Perkins 4.82) Thanks everyone for your help.
Perkins
These three engines (GA/GB/GC in Perkins' internal parlance) were developed especially for Mazda and were never offered by Perkins themselves.
S2 - 2.2 L (2,209 cc) - License built Perkins 4.135 related to HA and XA, used in 1979 to 1986 Mazda Luce, Bongo/E2200, B2200, Ford Ranger
XA - 2.5 L (2,522 cc) - License built Perkins 4.154 related to HA and S2, used in 1970 Mazda E2500 and 1971 Mazda Titan, and some Bobcat skid-steer loaders. A six-cylinder version of this is called the "YA".
HA - 3.0 L (2,977 cc) - License built Perkins 4.182 related to S2 and XA
All of these engines have cast iron blocks and heads, two overhead valves per cylinder driven by maintenance-free timing gears, crossflow heads, are indirect injection. US-market B2200 and Ford Ranger trucks - and possibly the others as well - had rotary Bosch VE-style injection pumps, built by Diesel Kiki under license from Bosch.
1453 (A57192)
1453 (A57192)
TANK MANIFOLD (A55745)
2011 Ford F450 Diesel with Just 156638 Miles (A56435)
2011 Ford F450...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Mini Metal Goat Statue (A55853)
Mini Metal Goat...
2013 MAXX-D BUMPER PULL TRAILER (A58214)
2013 MAXX-D BUMPER...
