MB60 (Ameriquip) Backhoe Leak (relief valve?)
   / MB60 (Ameriquip) Backhoe Leak (relief valve?) #1
Zyvek
Middle/West, Tennessee
1974 Massey Ferguson 135, Mahindra 2638, Case 1845c
I took the backhoe off of my tractor right after delivery. I only used it briefly so far..maybe 10 minutes to play a bit.
I went to hook it back up a few weeks later and noticed a leak from the part circled in red. I think this is a relief valve (if I'm reading the manual correctly). I snugged up the big nut (green arrow) and went work. Everything seems fine, and the leak is gone.
If this is a relief valve, should I have left the big nut loose? Should I worry I may have tighten it too much? or that there is an proper adjustment that I should have done. I think I turned it about 1/2 turn. I did not move what looks like an Allen head screw in the middle of the nut.
Thanks.
   / MB60 (Ameriquip) Backhoe Leak (relief valve?) #2
Thanks.
I found a manual for a MB80 hoe.
From what i could see they use shims to adjust the relief valve so if you did not touch the shims you did not change anything.
If yours does not use shims, from what you described you made no changes. You did not over tighten!
Dave m7040
Dave m7040
Thanks Dave!
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
2015 Cadillac Escalade ESV Platinum AWD SUV (A50324)
2015 Cadillac...
KJ 11'x19' Single Steel Carport (A50121)
KJ 11'x19' Single...
2024 JMR Stump Bucket Skid Steer Attachment (A50322)
2024 JMR Stump...
Satoh S-650G Tractor (NOT RUNNING) (A50774)
Satoh S-650G...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
