ROtella T-6 Synthetic Oil
   / ROtella T-6 Synthetic Oil #1
52wej
Gold Member
Central Virginia
2004 Century 2535 (3510 Branson equivalent), 2016 Kubota MX 5200
Do any of you have experience with the Rotella T-6 oil in your Branson? I have been using the T-4 15w-40 in my Century 2535 for years and thought about trying the T-6. The tractor has 1170+ hours on the motor. Thanks W. Jones
   / ROtella T-6 Synthetic Oil #2
I use it in my Branson 8050 also my IH 574 and 2015 Ram 1500 and the Kubota F2000.
As well as any small gas engines.
The only other 4 stroke oil I have in the shop is the Syn 3 for my bike and the left over Mobile 1 Deos 5w-30 that used to go in my wifes car.
   / ROtella T-6 Synthetic Oil #3
Every diesel I own runs on it. Never an issue even in the cold Wyoming winters. There was deal at auto zone for the T6, which came out to $7 per gallon after discount and rebates, limit 4 gallons per customer. I make my wife and a few friends help me stock up. I'm good on oil for at least 5 years now.
   / ROtella T-6 Synthetic Oil #4
My 2 red ones have had it all their lives; nothing else.
   / ROtella T-6 Synthetic Oil #5
I always get a kick out of "what is the best oil" discussions. I had a respected diesel mechanic tell me a few months ago to never use Rotella as he has seen to many engines with lube problems. I can't help from suspecting that there were extenuating circumstances in most of those cases. Personally, I think Rotella is fine, but also think most any good quality oil with the right specifications changed on a reasonable frequency will work as just well as the next one.
   / ROtella T-6 Synthetic Oil #6
Your friend sounds like a contrarian. Every answer is opposite from the established norm...my boss is like that and he's a pain in the *** to work with. But if you know this, go with the non established norm suggestion and usually he comes back with the established norm. I think he was a middle child and he had to go with the opposite to be noticed.
   / ROtella T-6 Synthetic Oil #7
   / ROtella T-6 Synthetic Oil #8
You are right Lou it is interesting. Wow, we have a tendency these days to turn everything into a competition that has to have a clear "winner"! Even if 10th place would work fine. My take on this to me is that it confirms that there isn't really that much practical difference in quality oils until you apply extreme conditions a normal engine wouldn't experience (i.e an oil temp of 425 F! If your engine oil gets any where near that hot in your tractor you should be worried about a heck of a lot more than just your engine oil!), and even in the out of normal circumstances the differences in oil aren't that great. The lubricity test results seem to me to be statistically insignificant unless multiple tests were run. I learned in school that lubricity (friction reduction) and wear are separate and independent attributes of oil. As an example, STP oil additive has been found to greatly reduces friction, but will actually increases wear, much like graphite does. He does point out things to consider like TBN, as it is fairly useful to avoid acid build-up if you go for long periods of time without changing your oil, so a high number helps you be a "winner". But in truth higher TBN's will, in long, term result in higher ash deposits in your engine, so a high number is not necessarily better or worse. If you change your oil frequently, high TBN's are probably detrimental compared to low TBN's. If you are lazy about changing oil, high TBN's are better.
I find it amusing and very telling when the narrator says toward the end he says he uses bargain basement Walmart's SuperTech in his personal vehicles.
   / ROtella T-6 Synthetic Oil #9
Yes, most of the current oils will do an excellent job of lubricating our engines in most cases.
In my mind for day to day use the detergents and cold flow abilities are important.
Then when winter comes around the pourability and flow characteristics take on a very important role,
for starting ability and quicker lubrication on start up.
I do use synthetics in every thing unless it's leaking and using quite a bit of oil.
My old Dynahoe 190-4 with its Detroit 4-53 gets straight weight 40, it is the only thing I have that does get a non synthetic.
I have used a lot of Amsoil, Mobile 1, HD Syn 3 and Rotella T6.
   / ROtella T-6 Synthetic Oil #10
I got in on that deal but it was cheaper than that a gallon here. They had it on sale for $19.99 in a box with 2 gallons with a $14.00 rebate. I wound up with 18 gallons total.
Each box of 2 had a free hat. I wound up giving them away, who needs 9 Rotella hats?
LandPride PFL1242 Pallet Forks (A50120)
LandPride PFL1242...
2015 Ford F-250 Knapheide Service Truck (A51692)
2015 Ford F-250...
Woods RM660 3pt. Finish Mower (A50774)
Woods RM660 3pt...
1028 (A51572)
1028 (A51572)
Club Car Carrryall 502 (A50121)
Club Car Carrryall...
Rears 500 Gallon Orchard Sprayer (A50120)
Rears 500 Gallon...
