Lnk
Gold Member
- Joined
- Feb 24, 2014
- Messages
- 368
- Location
- E TN
- Tractor
- Ferguson to-20, Deutz D7007, Yazoo yhr-60, Gravely 5240, Gravely C8 and model L,
Just picked up a 5204 with 40" grass mower and skulky (sp) for $75. Guy said it didn't work and there was water on the dipstick. He helped me load it in the pickup and I brought it home. Drained water out of oilpan, and gearbox. Seems it was left out in the rain for a while with no filler cap on the gearbox. Refilled with 30 weight oil. Pulled over a little hard. Pulled the plug and looked inside with bore scope. No pitting, light tan on cyli der walls. Added a spoon full of oil and rotated slowly. Left overnight, while I went and did some research.
Next morning, Sunday, I did a compression test with the pull starter. 130 psi, sounds good. Smelled varnish, so I took off the carburetor and cleaned it. Set the needles to 2 turns out. Checked spark, none. Found points dirty and closed. Found the "s" on the flywheel and set the points to .020". Set choke, pulled very hard. Automatic compression release not working. Pulled a couple more times and she pops.
Back off on the choke and she fired, and started crawling into my shed. Shut down, seems the neutral has no real detent on the direction or gear levers. The weight of the handles engages just enough to allow it to drive. Strap the drive lever into neutral and she runs great. Smoked a bit when it first started. Ran it for a couple of minutes and changed the oil again. A little milky, but clean.
Star it again and she runs and idles great. Adjusted gear select lever to ".010 between coils on springs for both high and low, as well as forward. Took it for a ride and she drives nice, but stutters under load, but doesn't stall. The points were Pretty bad before I filed them clean, fuel float it set correctly, doesn't seem to be lean or too rich. Plug is grey and sooty.
After it cooled down for a couple hours, I checked the valve to tappet clearance, .018" exhaust and only .005" on intake. Ground the stem to get .007 and reassembled. Still stuttering at high load.
I checked the condenser and it checks good. Carb cleaned up nice, tried to adjust carb richer but still stuttering. I ordered new point and condenser. Anything I am missing? Here is a pick from the ad, been too busy to take more yet.
