Trailer frame out of square 6x10
   / Trailer frame out of square 6x10
ten years ago or so I welded new axle hangers under my small tandem trailer. I don't know what I did wrong but one axle was spaced wider on one side than the other. I took it to an alignment shop and they they tweaked the axles until all the tires were tracking properly. One axle still is spaced wider on one one side than the other. It has never given any issues.
When ever I install a new set of tires on a trailer the trailer goes in for an axle alignment. It used to cost about $100/axle. It is money well spent.
I dont see any axle alignment short of modifying hangers or tongue. Have heard of axles that are adjustable but not my slipper springs. Hangers welded to frame and axle bolted to hangers via loop in springs. Adjustment would be handy.
   / Trailer frame out of square 6x10 #22
They use hydraulic jacks and bend the axles into alignment. I'm very satisfied with the process as it saves me a lot of money.
That makes sense, thanks.
Want to give all hearty thanks for all the suggestions. Will keep all for the future.
Anyway axle alignment fixed. Cut two small pieces of .125 falt bar, drilled holes and welded to existing hanger, holes actually engaged existing hanger...distance from axles to coupler bang on. Trailer bed still 3/16 out of square, but i do not believe its noticeable, albeit it will bug me. Now floor, sides and gate......great forum
thanks again all
   / Trailer frame out of square 6x10 #24
Smokeless I had spring mounts reworked on a 40 foot goose neck this spring. Big issue that trailer had was not enough travel between axle and frame. It was done with adding new axle mounts and reinforcing the mounting holes with heavy flat metal to thickening the spring mounting bolt.
   / Trailer frame out of square 6x10 #25
Pull diagonal measurements on the frame. Then find measurements from the front of the frame to the axle hangers. The diagonals will give you squareness of frame, and the measurements then from the front of the frame will be accurate. That is what is important. If the hitch isn't on square, it won't matter as much since it will mainly just pull off center a tiny bit. If your axles aren't square with the frame, it will be a bigger issue with tire wear and crabbing down the road.
Good stuff. The frame is not square, out 3/16", which is making the hanger deminsions tilt. Cant explain how, been too long. Was ill in 2016 and placed frame in barn, now back at it. Too many cross members in place, tongue, hangers to rearrange, so thought i would make sure axles in sync with coupler so it would pull true. Not sure i fully grasp crabbing. Your comments welcomed and appreciated.
   / Trailer frame out of square 6x10 #27
Crabbing is the tendency for the trailer to go "sideways" down the road, due to the axles not being square.
   / Trailer frame out of square 6x10 #28
Extreme, deliberate crabbing. Hitch is not perpendicular to axle's precise center. I kinda doubt the OP would need curb feelers for 'dog-tracking' but tire wear can be a real concern. IMO single axle trailers have to be more than a little skewed and driven far before they show much of it. (<1/4" off, meh :rolleyes:)
   / Trailer frame out of square 6x10 #29
Previously mentioned, tow it at highway speed on a good flat level road ( good luck on that one ) and momentarily hands free the steering wheel. That will quickly determine if there is a concern because just minute amounts of trailer wheel mis- alignment will pull the truck L or R and that will more than likely be in the (toe-in - toe-out) of the trailer wheels. All that other square stuff doesn't matter that much.
I will definetley try it, thanks. Really not anticipating any pull, like afore mentioned, trailer axles true to coupler, bang on....will report back thanks
1266 (A50490)
1266 (A50490)
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
PALLET OF EXTENSION CORDS AND AIR HOSES (A53843)
PALLET OF...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
2018 INTERNATIONAL LT625 (A53843)
2018 INTERNATIONAL...
