7060 R1W tires
   / 7060 R1W tires #1
JHurt
Gold Member
Hedrick, IN
M Farmall
Finally received a quote for a new 7060 today. One thing I asked for was the R1W tires that come on a 20" front wheel and a 30" cast rear wheel. The very first question I asked the saleperson was if the fronts are adjustable. He responded that they were, but after cruising through a bunch of posts with pics on here, I don't think that they are. I stole a couple of pics from another thread to add to the confusion.
Anyone know what size tires these might be? They look adjustable.
I believe these are the 20" wheels that come with the R1W wheels, and they don't look to be adjustable.
   / 7060 R1W tires #2
The standard sized "pizza cutter" front tires are supplied on two piece wheels that can be adjusted for width.
The optional metric sized tires are supplied on one piece wheels that can be adjusted into only two positions by moving the assemblies from side to side.
SDT
   / 7060 R1W tires
SDT
Do you know if you adjust them out if they match the width of the rears adjusted out all the way?
   / 7060 R1W tires #4
Unlikely.
The rear tires can be adjusted quite widely.
SDT
   / 7060 R1W tires #5
If you go that route,,, and since the salesman has told you they are adjustable,,, nail him if they aren't. Might even remind him again that he said they were. :)
Doing a grader deal with a tire issues. Specifically emailed the salesman so I have his "promise" in writing. :)
   / 7060 R1W tires #6
Saw one with cab and metric radials at dealer this morning.
Rear tires were adjusted fully inward. Front one piece wheels were as shipped (most narrow of two positions). Outside of front tires was about even with outside of rear tires.
Front tires can be adjusted to most wide of two positions by moving to opposite sides but rear tires can be adjusted outward more than this difference.
SDT
   / 7060 R1W tires #7
SDT
That is correct, however if you dish the wheels out they can interfere with loader mounts if fitted.
The 20" R1W radials have pretty well been standard on M series that size in Canada since the 40 series. I test drove an M5040 a few years ago that had the 20" radials dished out to the wide position and they rubbed on the Kubota (Orange ALO M loader) mounts on a full lock turn.100_1859.JPG
   / 7060 R1W tires #8
The 20" R1W radials have pretty well been standard on M series that size in Canada since the 40 series. I test drove an M5040 a few years ago that had the 20" radials dished out to the wide position and they rubbed on the Kubota (Orange ALO M loader) mounts on a full lock turn.View attachment 610744
PDI includes inspection and readjustment of the steering stops after installation of optional equipment, e.g., FEL, and tire width adjustment. Such inspection should include interference inspection including full steering lock at maximum axle oscillation but many (most?) dealers do neither.
SDT
   / 7060 R1W tires #9
SDT
Tractor in question was a used one that just came off the truck on trade, they had only drove it off the truck and parked it. They told me same thing you did and it could be fixed, so if steering stops resolve that, great, just be aware your turning radius might be affected in the wide position. PO must of just flipped the rims to make it wider and did not so anything else.
   / 7060 R1W tires #10
Agreed.
One of the things that I do after taking delivery of a new tractor is to check the steering stops. Usually, I can turn both sides in substantially even after checking for interference with FELs, brackets, etc. Doing so decreases turning radius but requires the front of the tractor to be lifted with FEL, jack, etc., to fully oscillate the front axle.
Manufacturers usually ship tractors with the steering stops adjusted conservatively to avoid interference regardless of what options the purchaser specifies.
Of course, this must be re-done if the front tread is subsequently changed.
SDT
2021 CASE IH 345 (A53084)
2021 CASE IH 345...
2015 KENWORTH T800 (A52472)
2015 KENWORTH T800...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
2014 Freightliner M2 106 Ambulance (A50323)
2014 Freightliner...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
John Deere 7500 Reel Mower (NOT RUNNING) (A50774)
John Deere 7500...
