1510 Starter problems
   / 1510 Starter problems #1
LD48750
SE, MI
Ford 1510 Mahindra 1526
Starter switch has been acting up for the last couple years.
Previous owner installed a starter button and that has been working fine UNTIL yesterday.
Jumped it with a screwdriver once & everything was working good again.
Today nothing.
Battery good jumping with screwdriver gets nothing, not even a click.
Trying to take starter off to run up to repair shop & can't get it out.
Part of the hydraulic system is in the way.
Is there a trick to getting the starter out or do I have to break open the hydraulics?
Here is some pics for your big brother 1710 that might help. Starter removal Ford 1710 - Yesterday's Tractors
Yup... That looks like it.
But just like that poster, I cleaned everything up & put it all back together (without getting it out of the tractor) and IT WORKED!
Well.... twice anyway. Then back to the screwdriver.
Going to order an ignition switch & see if that helps.
Most of what I find says this tractor is self priming so if I do have to get into the hydraulics it shouldn't be bad.
Well... I have ordered a new starter key switch.
Will try using a jumper cable and see if that indicates a bad cable.
Today was hit & miss, switch worked part of the day then quit.
Screwdriver to the rescue.
   / 1510 Starter problems #6
Check all connections including the ground to the frame. I had some issues on my 1920 and the ground to the frame was rusty, cleaned it up and no more issues.
2012 SANY SRC 840 4x4x4 40 Ton Rough Terrain Crane (A60460)
2012 SANY SRC 840...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A59905)
2018 INTERNATIONAL...
2024 CATERPILLAR 255 SKID STEER (A52709)
2024 CATERPILLAR...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
large capacity skid steer bucket (A56857)
large capacity...
