Thinking ahead.... keeping a Pressure Well Tank from freezing
   / Thinking ahead.... keeping a Pressure Well Tank from freezing #11
Unless you are on top of Mt. Hood you should not need any sort of dedicated heater, other than a light bulb or two.
:thumbsup: :thumbsup: :thumbsup: . . .all three of my wells have nothing more than a light bulb, never have frozen up. I am at the 7-8 hundred foot level.
   / Thinking ahead.... keeping a Pressure Well Tank from freezing #12
Yep....if you have a basement, that's where it needs to be.
Water room in my basement. Well tank located there, plus the spring water line (2 separate systems) with booster pump and UV light.
enhance
enhance
And everything that will ever need maintenance right there handy, not in a hole in the ground.
   / Thinking ahead.... keeping a Pressure Well Tank from freezing #13
I couldn't find anything on google for Hughett Bend, but Molalla is west side, and you don't get much cold weather there. East slope winter low temps are at least 20 degrees colder, and it's not unusual to get a couple days of -20.
   / Thinking ahead.... keeping a Pressure Well Tank from freezing #14
You know Larry - I looked and I couldn't find Hughett Bend anywhere in WA either. And I'm pretty familiar with most small towns here in Ea WA. Oh, well - plenty of good solutions presented here.
   / Thinking ahead.... keeping a Pressure Well Tank from freezing #15
Go to the farthest spigot and let Drip at night the warm water in the holding tank will keep it and your pipes from freezing on the coldest nights
   / Thinking ahead.... keeping a Pressure Well Tank from freezing #16
The other WA is Western Australia, but I don't think they get much cold weather there.
The other CA is Canada. :)
2018 MDB LV600 GREEN CLIMBER SLOPE MOWER (A51406)
2018 MDB LV600...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A52377)
2017 Mack GU713...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
2007 International 4400 2,000 Gallon Water Truck (A52377)
2007 International...
KMC 5610 LOT NUMBER 33 (A53084)
KMC 5610 LOT...
