7060 R1W tires
   / 7060 R1W tires #11
They offering a second radial now with a lower profile larger rims Goodyear and has a tread pattern with more in the middle so they smoother on the road and lower profile makes less choppy, but will hold less fluid
   / 7060 R1W tires #12
How did your price quote compare to MSRP (price on Kubota you build it site)?
   / 7060 R1W tires
I believe the website was $53,xxx, and the dealer quoted me $48,200.
   / 7060 R1W tires #16
HDC12 with loader?
No cab. MSL FEL, 3rd function, 3 rear remotes, cast iron rear centers, triple rear weights, 1000lb front weights. Very well equipped.
   / 7060 R1W tires
Told the salesman to order it today!
   / 7060 R1W tires
I was told it would be here in two weeks today!
   / 7060 R1W tires #19
Hmm - - the picture shows that there is only two settings. Dish in - dish out. The front rims on my 2009 Kubota M6040 have the same ability to be adjusted as my rear rims. There are eight differing settings. I have my rear rims set out to the max and fronts are at a near neutral setting.
My tires are OEM - six ply - bias - Titan/front - Firestone/rear.
A photo of my front tire/rim
   / 7060 R1W tires #20
Yep. You don't have R1W tires.
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
CFG Industrial MX12RX (A50121)
CFG Industrial...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2018 Caterpillar D5K LGP Crawler Tractor Dozer (A50322)
2018 Caterpillar...
Parkson 3000A Feed Mill (A50121)
Parkson 3000A Feed...
