Who sell PTO clutch for Toro GroundMaster 120 model 30612 serial 890142
   / Who sell PTO clutch for Toro GroundMaster 120 model 30612 serial 890142 #1
videorov
Member
The one I took off is a OGURA M-GT-TROC trying to find another one at a good price????????????
Who has them???????? Toro part# is 54-0220.
Pictures of the one I just took off.
I tried the Fatboy Extreme and the pulley was to thick or wide so I could not get it behind the frame of the 120 to get it on the shaft. I haven't tried the
Stens. One clutch a company sent me had the square key in the center instead of having the notch which I need. Had to send it back.
I need one with the notch so it can slide over the square key already on the shaft like the one in my picture with the shaft.
I will have to look up the Stens 255-210 and see what it looks like if I can find it on the net.
Im still looking????????????????????????????????? The guy on ebay has not replied back yet.
   / Who sell PTO clutch for Toro GroundMaster 120 model 30612 serial 890142 #6
The Amazon one appears to be the same extreme one as the EBay. Look at the number. Says Fatboy too. Same clutch PSEP.
Here is an Ogura from Rotary OGURA ELECTRIC PTO CLUTCH FOR FERRIS
I tried a Fatboy one time and it won't fit between the frame and the shaft when you try to get it install it. The thicker pulley makes it to wide to get
in to position. This model of Ogura is the only one that seems to fit. MA-GT-TROC
   / Who sell PTO clutch for Toro GroundMaster 120 model 30612 serial 890142 #8
Then I'd say your choices are to do something to improve clearance so that you can install the other clutch or buy the same OEM clutch.
If there is way to get one of the Extremes on there it would nice to know how they did it. Those are around $189 and the OGURA M-GT-TROC is $440 and
not worth it since I only seem to get around 4 years out of them just mowing around my home about 2 acres and don't use it for commercial use.
Maybe someone out there know how to insatll one onto the Groundmaster 120 would be nice to know how they did it.
I hate to spend the $440 for the other one.
   / Who sell PTO clutch for Toro GroundMaster 120 model 30612 serial 890142 #10
the square key on the engine shaft can be removed..
1274 (A50490)
1274 (A50490)
2015 Volkswagen Passat Sedan (A51694)
2015 Volkswagen...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
2017 Isuzu NRR Box Truck (A51692)
2017 Isuzu NRR Box...
1999 CAT TH63 (A50123)
UNUSED CHERY INDUSTRIAL SINGLE GARAGE METAL SHED (A51248)
UNUSED CHERY...
