3rd function kits....proportioning or not?
   / 3rd function kits....proportioning or not? #11
I'm running my dual lid grapple off a manual valve mounted on the fender near the loader joystick. I can feather the grapple but I've never wanted to. I hold the lever down until the material stops crunching.
A single lid with the same size cylinder would open/close twice as fast. That might want feathering at times but at least for me, probably not.
You could put in fixed or adjustable restrictors to slow the rate if needed.
Thanks, I've got some adjustable flow valves from my big skid steer that I'm going to plumb in and just go with a 3rd function kit. It'll be fine for my purposes.
   / 3rd function kits....proportioning or not? #13
I'd get the feather, you never know when you might need to pick up something you don't want to bend or destroy.. JMO..
It's $800 more than the 3rd function kits I'm considering. If you want to give me the extra, I'll do it.
   / 3rd function kits....proportioning or not? #15
You asked for opinions, if you can't afford what you're asking about,, DON"T ASK!:thumbdown:
   / 3rd function kits....proportioning or not? #16
Simply tap the button and be as gentle as you need.
Didn't say I can't afford it. Alluded it was foolish to spend that for the ability to feather. Sorry you didn't catch that.
   / 3rd function kits....proportioning or not? #18
Jeez dude. I'm with 1010. You asked for opinions, but now the ones you decided against are "foolish"?? Why bother asking?
ok
noted
   / 3rd function kits....proportioning or not? #20
I agree. Easiest and cheapest is diverter. Then as more features are added, cost climbs. If money is no object, go for 3rd function with control feature.
Woods 18ft Batwing Rotary Cutter (A56438)
Woods 18ft Batwing...
KOMATSU D61PXI-24 CRAWLER DOZER (A60429)
KOMATSU D61PXI-24...
2019 GALYEAN 150BBL STEEL (A58214)
2019 GALYEAN...
2010 Deere 318D (A60462)
2010 Deere 318D...
2021 TAKEUCHI  TB260 (A58214)
2021 TAKEUCHI...
SDLL30 skid steer with bucket (A56857)
SDLL30 skid steer...
