Hole in my oil pan!
   / Hole in my oil pan!
My friend pounded it out straight, fabricated a patch out of a small piece of old tail pipe he had laying around, used a wire feed welder, welded one edge, pound the next edge into shape, welded that edge, pounded the next edge to shape .... etc. Then he welded it again from the inside. Will be good as new. I have lost a tablespoon of oil capacity though:) He is certain that I ran over a piece of t-post fencing or something similar. He may be right. You'd think a rock would smash a bigger area and not make such a clean tear. Now to put it back together.
I have been scratching my head on what that oil pressure icon is supposed to represent. It's either an oil pump or a rod journal with a weird bearing. I agree that an oil can is the standard understandable icon for oil pressure. I get a kick out of the soot scrubber icon too. It shows a shower head blowing water or something. How the heck does that relate?
   / Hole in my oil pan! #22
I thought the DPF icon represented an exhaust pipe blowing lots of soot. The oil pressure warning and probably the DPF symbol are ISO standard symbols. The outer part of the oil pressure symbol is common for all engine related symbols. I think it represents a crankcase. The inner droplet part is used for all engine oil related symbols.
Here's the applicable standard. It's a large PDF. The engine oil related ones are on page 14.
https://webstore.iec.ch/preview/info_iec60417{ed1.0}b.pdf
I've worked on standards committees and while they're often imperfect or downright disfunctional, at least there's a standard.
   / Hole in my oil pan! #23
I just saved that doc - wow it will answer a lot of questions! Thank you.
   / Hole in my oil pan! #24
Good to hear! T-post seems a likely culprit.
Tradewinds Power Unit (A50120)
Tradewinds Power...
Toro Workman 175 Sprayer Cart (A50324)
Toro Workman 175...
2007 STERLING T/A DAY CAB ROAD TRACTOR (A51243)
2007 STERLING T/A...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A52748)
JOHN DEERE ROW...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
2005 Ford F-250 4x4 Reading Crane Service Truck (A51692)
2005 Ford F-250...
