3 point mount / tractor hydraulic log splitter on a JD 2840
   / 3 point mount / tractor hydraulic log splitter on a JD 2840
Photo below shows how CC plug converts an open center control valve if it's the convertible type valve.
TX Jim, That really does help. I sent a message to the seller to let them know that I was interested but I had to figure out how to adapt it to the JD 2840 closed center hydraulics. They were kind enough to respond and let me know that I did need a closed center control valve to make it work. I did some searching and ran across the CC plug and wondered if that is all I would need to convert it. Otherwise replacing the whole control valve could add some cost to the purchase. Thank you for that information, I know what to research to see if it can be converted easily. If not, I will look for a similar model that supports that. Thanks!
   / 3 point mount / tractor hydraulic log splitter on a JD 2840 #22
From viewing your original photo of splitter the valve doesn't appear to be CC convertible type but casting # on valve housing would help determine valve type. On a side note splitter frame is designed for Cat l so you'll need to turn 2840 3pt sway blocks 90° & acquire some Cat l to Cat ll bushings
From viewing your original photo of splitter the valve doesn't appear to be CC convertible type but casting # on valve housing would help determine valve type. On a side note splitter frame is designed for Cat l so you'll need to turn 2840 3pt sway blocks 90ー & acquire some Cat l to Cat ll bushings
That lines up with what the seller said. Sounds like I would have to replace the existing control valve completely. I am going to look at either the Northern Tool Powerhorse 11965 or maybe better yet the Dirty Hand Tools 100450. Neither manual says anything about having a CC conversion plug option. I may have to call their support to check.
https://www.northerntool.com/images/downloads/manuals/11965.pdf
https://www.logsplittersdirect.com/manuals/100353_OM.pdf
Thank you for all of the insight!
Mark
   / 3 point mount / tractor hydraulic log splitter on a JD 2840 #24
Good morning. I'm curious if you ended up buying the used one; or purchased a new one? I am also looking for a Cat 1 splitter. I've been splitting wood all summer by hand. While it's good exercise, I also really could use the time savings on other aspects of keeping the property up. I've got a JD1025 and also could use some guidance on making one work for my setup.
   / 3 point mount / tractor hydraulic log splitter on a JD 2840 #25
Your pump flows 3.5gpm. A small (4" cylinder) dedicated splitter runs 11gpm or so. Larger ones are 16 or more.
3.5 gpm will be frustratingly slow. Get a regular dedicated splitter.
2015 Revere Shasta 27DB 5th Wheel Travel Trailer (A51694)
2015 Revere Shasta...
2004 Sterling Acterra Cab and Chassis S/A Truck (A51692)
2004 Sterling...
2017 S-60X MANLIFT (A51246)
2017 S-60X MANLIFT...
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
2009 FREIGHTLINER BUSINESS CLASS M2 CRANE/POLE TRUCK (A51406)
2009 FREIGHTLINER...
