rebuilt a Howse HD10 bush hog... have a question
   / rebuilt a Howse HD10 bush hog... have a question #1
Little General
Mi. Pleasant , N/C/
Kubota M7060 w cab Kubota x1100c Kubota KX008 John Deere 4400 , JD TLB110
I aquired a Howse HD10 bush hog that had a busted gear box on the right side. I found a dealer that bought all Howse stock when they closed. Anyway when I put the stump jumper back on I made sure the left side blades were north to south and the right set east to west. I also made sure they sets were not mixed up like it was when I got it. It mows real good but makes my tractor wobble a tad. It could be the nature of the beast. Not bad , but I know its running.
   / rebuilt a Howse HD10 bush hog... have a question #2
I will say that with my LP RCR2596, I get a noticeable wobble unless I am at 540
Blaszer, any way you could look under your bh and check the orientation of the blades ?
   / rebuilt a Howse HD10 bush hog... have a question #4
Little General:
you might consider a new blade set. sharpen existing & keep as back up. you'll need replacements @ some pt anyway. new ones might run smoother & more balanced.
   / rebuilt a Howse HD10 bush hog... have a question #5
My 8 foot twin are orientated the way you have yours. I would agree it sounds as if you have a blade balance issue.
   / rebuilt a Howse HD10 bush hog... have a question #6
Little General:
I was going to post the same thing these guys did ^^^^^ sounds like a blade issue, that they are not balanced. You have them correct orientation. The only other think (doubtful) is a blade is hungup and not swinging out, this usually happens if the blade pin/bolt get fouled with mowing debrie, so doubtful.
   / rebuilt a Howse HD10 bush hog... have a question #7
Yep, you have your blades right.
I would try swapping blades like other people have said. Let me know!
It痴 not that bad , kind of like a tire out of balance on your truck.
So , today I took all the blades off the HD10 aand weighed them. All but one weighed 11.5 pounds. One was 2 ounces below , so I welded a flat piece of plate on the blade to get it to weigh the same. I also switched which sides of the stump jumper each blade was on. After I cool off in the shop I'm going back to the field to see if that helped.
   / rebuilt a Howse HD10 bush hog... have a question #10
Did it work?
2012 PETERBILT 388 NATIONAL CRANE TRUCK (A50854)
2012 PETERBILT 388...
2018 Dodge Ram 3500 4x4 Utility Flatbed Truck - HEMI Gas, Gooseneck Hitch, Southern Truck (A51039)
2018 Dodge Ram...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
C13 MOTOR (A50854)
C13 MOTOR (A50854)
1043 (A50459)
1043 (A50459)
