Cast iron cooking on electric stove
   / Cast iron cooking on electric stove #11
You can use cast on the glass top it just scratches if you slide it.
   / Cast iron cooking on electric stove #12
the tops are made of ceramic, not glass, and is much harder than steel or cast iron. if anything, you'd scratch the cast iron. but be aware, the ceramic tops will crack if you drop a cast iron pot on it. also, sugars make them crack, so if you really want to use cast iron pans, it's safer to avoid ceramic tops, which some people call "glass"..
   / Cast iron cooking on electric stove #13
You are correct, they are ceramic. We all call them glass though. And my top sure has scratches all in it. Plus I read the part about dragging them scratching it on the net so it must be true. Haha I googled it cause you always hear you can't use cast on ceramic cook tops.
   / Cast iron cooking on electric stove #14
Are we talking about induction or radiant heat tops?
   / Cast iron cooking on electric stove #15
From my 15 minutes of research I believe that all electric cooktops with a smooth finish are made of a material called "glass-ceramic":
Glass-ceramic - Wikipedia
There are, of course, multiple manufacturers and the durability and scratch-resistance of their products will vary.
Confusingly, it seems that in some parts of the world manufacturers market induction cooktops as "Induction" and the old-style cooktop that heats the pot by radiant heat as "Ceramic" or "Glass-ceramic".
Chris
   / Cast iron cooking on electric stove #16
My wife does a lot of cast iron cooking on our glass-top stove. We also have a big cast iron griddle that lays over two burners and it's great for pancakes. That came with the stove as an accessory. When I make pancakes, I let that thing heat up for 10-15 minutes on low heat and it does a great job (I'm a sucker for good pancakes).
Good to hear. Induction would be great, but that then takes us to the non magnetic SS pans. I assume that they work the same w/ a steel disc below them? Or is that a PITA? Really, all that is required here to keep her happy is to change the laws of physics...
   / Cast iron cooking on electric stove #18
With an "induction interface disk" the induction unit heats up the interface disk using its magic and then the interface disk heats the pot sitting on top of it through radiant/convective/conductive heating, like a less expensive radiant heat electric stovetop works. This might be a solution to use for one particular pot/pan so that it could continue to be used with a new induction unit, but using it with most of your pots/pans would be an expensive exercise in turning an induction cooktop back into a radiant heat cooktop.
Chris
   / Cast iron cooking on electric stove #19
Stuff sounds way too expensive. My $300 LP stove does all I need and costs almost nothing to use over the course of a year. Electric would kill my budget.
I have a ceramic cook top I bought in the late 80s sometime. Sets in to a counter top, not a full range. It's full of scratches and dings just from the few times I used it. I tried using foil under the pans to minimize the surface damage. Bits of foil fused to it and I can't get them off.
   / Cast iron cooking on electric stove #20
what scratches them is if you put a glass or ceramic bowl or plate on it, and move it around, some people use the cooktop as a mixing or serving surface.. that's what scratches the cooktop!. I use a razor blade to remove burnt on food from my cooktop, and it NEVER scratched the surface!..
2008 Cadillac DTS Sedan (A53117)
2008 Cadillac DTS...
2018 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2018 John Deere...
1997 Dynapac CC142 14 Series Double Drum Roller (A52384)
1997 Dynapac CC142...
2005 Ford F-150 Pickup Truck (A51692)
2005 Ford F-150...
CFG Industrial SAII100 (A50123)
CFG Industrial...
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
