Hydraulic tank cap damaged by seat
   / Hydraulic tank cap damaged by seat #22
I will take a picture later on of my 1430 where the center pivots are, and we can at least see what it looks like being greased every eight hours.
What does PT say about greasing that front/upper pivot under that plate? Every 50 hours? Anyway, I wonder if it would help to grease it more often?
   / Hydraulic tank cap damaged by seat #23
Every 8 hours. It's kinda hard to get to on my 425. So much so, that I removed the plate. Someday I'll notch it and put it back.
   / Hydraulic tank cap damaged by seat #24
I was told to grease the 3 center pin fittings every 50 hours.
   / Hydraulic tank cap damaged by seat #26
This is my manual here and it says to grease the upper and lower center pivots every 8 hours, and the upper front under the plate every 50 hrs. Here are the pictures of the manual, and the upper and lower pivot areas. The upper one definitely has grease all around it, and the bottom is hard to see, but it seems like the grease stays more near the top than the bottom?
   / Hydraulic tank cap damaged by seat #27
This comment may not apply to Bob's situation but it does pertain to new seats and damage to tank caps.
I replaced by stock seat with a suspension one. I'd read someone had done that and to gain some headroom, had drilled two new holes in the pivot bar that connects the seat to the tractor. I did the same, about 2-3" higher than the stock holes. It did provide more head room and it did clear the tank cap as long as the tractor was not articulated.
It was just too close to the tank cap for comfort so I took it outside to see what would happen when the center joint was pivoting up and down. It would have torn that cap right off. I ditched the low rider idea and stuck with the stock position. A little less headroom but my tank cap remains intact.
   / Hydraulic tank cap damaged by seat #28
Why are your wheels so far from the machine? Did you reverse the rims?
   / Hydraulic tank cap damaged by seat #29
yes I did, and yes, I've been forewarned :)
EZ-GO MPT 1000 Electric Utility Cart (A51694)
EZ-GO MPT 1000...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A51248)
UNUSED RAYTREE...
Kinkaid 1200 LS-PH Towable Hydroseeder (A51691)
Kinkaid 1200 LS-PH...
2019 TEREX PHOENIX 2100 TROMMEL SCREEN (A53426)
2019 TEREX PHOENIX...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
