Want a machine that will mulch leaves...lots of leaves.
   / Want a machine that will mulch leaves...lots of leaves. #1
shooterdon
Elite Member
Near Johannesburg MI but in the middle of nowhere
2019 LS XR4140 HST Cab; 2020 Kawasaki Mule SX; 2021 Bad Boy 54" ZT Elite
Tried of bagging and blowing. I spend almost as much time removing leaves in the fall as I do mowing all year. My Husqvarna YTH24 with bagger is what I am using now.
I want a machine that will cut grass and mulch leaves. I have about 2 acres of lawn to tend. 2 dozen trees in the lawn area and surrounded by woods. Trees are oak, maple, birch and poplar.
I was all set to buy a Country Clipper from the local Amish dealer, but he was honest, and told me it was a poor choice for mulching.
Prefer a ZT but a rider is fine if it does the mulching job. Budget is $5k.
Thanks for any guidance.
   / Want a machine that will mulch leaves...lots of leaves. #2
I just made a plate of 1/8 aluminum to bolt over the grass outlet of my Exmark ,and it does a good but dusty job mulching. If I can I try to mulch after a rain to cut down on dust.
   / Want a machine that will mulch leaves...lots of leaves. #3
I live in the woods and am surrounded by 100's of trees. I got a Cyclone Rake and I use it with my zero turn. In the fall I use it about 3-4 times and it takes care of all the leaves. Works very well.
   / Want a machine that will mulch leaves...lots of leaves. #4
Second vote for a cyclone rake.
I've gotta add its a clumsy appendage on a lawn tractor but it does the job. We had 6 acres, 2 cleared, when we had it with lots of trees. And oaks in Florida will drop leaves if you look at them crooked. In Sandy spots it did almost too good a job.
   / Want a machine that will mulch leaves...lots of leaves. #5
I use a Trac Vac 580 - it has a metal 27 Cu Ft box for collection and a Ferris Zero Turn with Gator mulching blades. For the first few light leaf falls I just mulch them down to fine bits, then when the trees drop most of their leaves I mulch and window them then collect with the trac vac.
This is on about 2.5 acres with at least 30-40 oak and maple trees. There are a few units available locally here - the DR looks to be a nice sized unit - 8 or 10 HP engine. THen there is a cyclone rake - small one for a great price $500. northern MI for sale "leaf vacuum" - craigslist
The cyclone rake would work behind your current tractor, and invest in some gator blades too - they make a big difference.
   / Want a machine that will mulch leaves...lots of leaves. #6
Yeah buddy on the Gator blades!
   / Want a machine that will mulch leaves...lots of leaves. #7
If you want to go cheap, buy the mulching kit and mulching blades for your Husqvarna YTH24. It'll do a good job and keep the chopped up leaves there for fertilizer.
   / Want a machine that will mulch leaves...lots of leaves. #9
Doesn't there come a point at which there are simply too many leaves for mulching in place?
   / Want a machine that will mulch leaves...lots of leaves. #10
We have very large willow oaks in our yard (among a lot of other tress in our yard and around us) and I constantly fight leaves in the fall. I have a zero turn with a 54" deck, bought a Trac-Vac at an auction like new for less than half the price of a new one. Hooked it to the ZT and spent more time unclogging the hose than getting leaves up (deck puts out to much for the hose to handle). A friend gave me an older Cub Cadet with a 32" deck. I was going to get rid of it but decided to hook the Trac-Vac to it. Got leaves up with it 2 years ago and never once stopped to unclog the hose. Used it last year and did great again.
I blow my leaves away from the house, take the ZT and mow/mulch them into rows then take the Cub Cadet with the Trac-Vac and get them up. It's a lot of work but you got to do what you got to do.
I have learned to not try and get leaves up when they are the least little bit wet, it's a pain.
71064 (A49346)
71064 (A49346)
Round Bale Feeder with Skirt (A50515)
Round Bale Feeder...
2011 CATERPILLAR 259B3 SKID STEER (A51242)
2011 CATERPILLAR...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
SET OF (4) TITAN MULTI TRAC C/S TIRES & WHEELS (A51244)
SET OF (4) TITAN...
2013 Chevrolet Cruze LS Sedan (A50324)
2013 Chevrolet...
