kubota b7500 front brush guard fabrication & harbor freight lightbar
   / kubota b7500 front brush guard fabrication & harbor freight lightbar #11
I thought the newer Kubby's had real headlights as in Halogen instead of the filament flashlight bulbs my M's have?
   / kubota b7500 front brush guard fabrication & harbor freight lightbar #12
Mine are a 2012 L3200 and a 2008(?) L4240HSTC. Never looked to see what bulbs are used. The 4240 light housings look neat, but don't make decent light where it's needed. Perhaps the newer ones are different.
   / kubota b7500 front brush guard fabrication & harbor freight lightbar #14
Double check that link I posted, takes me right to the Larson page... either way, the 4" light is a common size for big rig tail lights, work lights, and such, as well as ag equipment. Keep looking, you will find a replacement that fits.
   / kubota b7500 front brush guard fabrication & harbor freight lightbar #15
Hi Dieselcrawler
Yes the round lights in the grill are factory they are 4" round sealed beam type. everything I find is larger than 4"
The link you posted doesnt work. I get a .net error....
I will look some more today and then remove the lightbar. I needed it yday so it worked for my purpose but its not good for a permanent install.
Thanks for the reply
spirostats - The headlights on my 2003 B7500 HSD-R are not sealed beam. They use an 1156 (BA15s) bulb. There are many LEDs that will work in the sockets, however many (most?) are too long to fit into the housing. These are what I am currently using:
https://www.amazon.com/Antline-12-2...7827&s=gateway&sprefix=antline,aps,181&sr=8-7
They are not great, but are better than OEM. There are probably brighter ones available now, just be careful on the length.
   / kubota b7500 front brush guard fabrication & harbor freight lightbar #16
Spirostats - I like the frame shape. How did you make the bends in that heavy flat stock? You did a good job making them the same for both sides.
   / kubota b7500 front brush guard fabrication & harbor freight lightbar #17
If it's like ours was, the whole housing was junk. I replaced it with a pair of LED lights:
Aaron Z
Im sorry I somehow forgot to subscribe to the thread and have not been notified of your post. I just saw it now. I ordered these ones today from asmazon https://www.amazon.com/gp/product/B01KJ94Q1K/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=. We ll see how it goes
As far as bending the metal....no special technique. I made a mock up using a thick aluminum wire and kept checking the angle little by little as I was bending it on my harbor freight 20 ton press which is equipped with a "swag offroad" brake.
I want to thank everyone for their suggestions. I ordered the headlights and will later put the lightbar somewhere else to use as an auxilary. I will update this when I figure out where. In the mean time I fabricated a hook mount for the bucket. Here it is ...
PS I also added another angle brace on the other side for symmetry ......I have a "slight" case of OCD ...:(
@ Rusty. Sorry man....mine are not sealed either.....Im an idiot. But the plugs where destroyed like aczlan said. Hopefully the ones I got will do.
2013 International DuraStar 4400 Altec AM547 50FT Material Handling Insulated Forestry Bucket Truck (A51692)
2013 International...
2018 FORD F-450 XL FLATBED TRUCK (A51406)
2018 FORD F-450 XL...
2016 Case 821F Articulated Wheel Loader (A51691)
2016 Case 821F...
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51243)
(INOP) JOHN DEERE...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
NEW Work Saver Skid Steer/Sub Compact Grapple (A53472)
NEW Work Saver...
