How do you verify if the tow/haul button actually works?
   / How do you verify if the tow/haul button actually works? #1
4570Man
Super Star Member
Crossville, TN
Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
I’ve got a 2500 suburban with a 4l80e transmission. It seems like the tow haul function is staying on despite the little trailer emblem going off. It’s pushing the shift points high and doesn’t seem to be shifting into OD. I need to experiment with it more tomorrow.
   / How do you verify if the tow/haul button actually works? #2
What year Suburban? Just curious.
   / How do you verify if the tow/haul button actually works? #4
Mine is very noticable on or off.
I’m pretty sure it’s staying on all the time but when I press the button it’ll turn the trailer emblem on and off.
   / How do you verify if the tow/haul button actually works? #6
Could be the pressure control solenoid going out too.
   / How do you verify if the tow/haul button actually works? #7
Like they said, should be noticeable. If not, would have to use scam tool to verify that input and if trans has any problems.
   / How do you verify if the tow/haul button actually works? #8
Hahahaha. "Scam Tool". I need one of those!
   / How do you verify if the tow/haul button actually works? #10
Not that it's related but the wire on my F150 shifter got chafed and was keeping the OD light on. It wasn't disengaging the OD and the switch would still function. I replaced the shifter with a generic one from O'Reilly.
2015 Freightliner Ambulance (A50323)
2015 Freightliner...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A52128)
2016 KBH...
UNUSED FUTURE MINI EXCAVATOR RAKE (A51244)
UNUSED FUTURE MINI...
BUNDLE OF GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF...
UNUSED AGT H15R EXCAVATOR (A51243)
UNUSED AGT H15R...
