Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #9,412
I got another load of paid to haul off wood. They even cut most of it and helped load it. IMG_7422.JPG
   / Tractors and wood! Show your pics #9,414
Nice. Only down side to tree company firewood is they do not (sometimes cannot) cut to a uniform length.
Most tree guy wood is astoundingly terrible. I’ve about got this crew trained to cut useable firewood. It’s still probably plus or mini 4” but that’s good enough.
   / Tractors and wood! Show your pics #9,415
We burned a couple of sticks of white pine in the fireplace last night, from the huge tree that we had cut up in the spring and stacked. It seemed dry enough and was very light, and seem to burn OK with no “sizzle“.
Do you think it will be OK to burn this winter? We are not looking for BTUs, just ambience.
   / Tractors and wood! Show your pics #9,416
Pine dries fast, especially if you split it. We often used to cut wood in August to burn that winter, and it seems like we would cut gray birch in October to burn in fall and spring fires.
   / Tractors and wood! Show your pics #9,417
Built another take off/drying rack for lumber coming off my mill
   / Tractors and wood! Show your pics #9,418
Started retrieving some of the trees I have on the ground for my sawmill, cut 8s,10's,12s,and 16 footers.. all plus 6 inches of course.
Now if I could only get the pics to come out right side up!!
   / Tractors and wood! Show your pics #9,419
I figure tree guys are mostly taking trees down because they are diseased, rotted or a danger tree, much of which is going to yield some marginal wood. But the majority of it is often still good.
   / Tractors and wood! Show your pics #9,420
Looks to make for some good milling there! Nice.
Black Steel Diamond Plate (A55758)
Black Steel...
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
CAP STRING PRIMING SKID (A55745)
CAP STRING PRIMING...
70pc. 12ft. x 3ft. White Metal Roof/ Wall Panels (A53424)
70pc. 12ft. x 3ft...
