Kioti NX5010 ground speed surges when holding foot pedal steady
   / Kioti NX5010 ground speed surges when holding foot pedal steady #11
Keep us posted because mine does it in reverse!!! :mad:
So it may be an isolated one of a kind issue......or.....it may be related to the issue some of us have with air entrainment/foaming/ 3ph jumping...etc
Service Rep. came to my house, and simply re-calibrated the computer. It took him about 5 minutes. This is done with the tractor turned off. Through a series of special sequence of buttons and levers, IE (depress brake pedal, push the CAL button, Key On, then Neutral, to Low to Neutral to Medium, to Neutral to High) Etc.... Finally Key Off, to save. Unit is now AWESOME!
   / Kioti NX5010 ground speed surges when holding foot pedal steady #13
Good to go! May want to keep the calibration procedure handy in case it happens again.
Here you go.
KUBOTA X1140 CREW RTV (A52706)
KUBOTA X1140 CREW...
New/Unused Pallet of Webbing Slings (A54865)
New/Unused Pallet...
KUBOTA SVL95-2S SKID STEER (A52707)
KUBOTA SVL95-2S...
2005 International 4300 Telsta Telescopic Bucket Truck (A55973)
2005 International...
Yellow Steel Diamond Plate (A55758)
Yellow Steel...
(NEW) 2022 Greenworks CU400W Commercial Work Utility Vehicle (A55302)
(NEW) 2022...
