Removing weld seam in tubing
   / Removing weld seam in tubing #1
k0ua
Epic Contributor
Branson, Mo.
Kioti DK35se Hydrostat
I never really knew how to do that before. I am getting smarter every day I tell 'ya! :)
   / Removing weld seam in tubing #2
Neat ideas and methods in that video and it's easy to watch too. I have used the file method and bought some special tubing with the weld removed at a premium price. His simple tools seem to work good. Thanks for posting.
gg
   / Removing weld seam in tubing #3
Thanks for the video.
Jim.
   / Removing weld seam in tubing #4
You guys are welcome. I found it interesting and possibly could save you some money for just a little work and some materials.
   / Removing weld seam in tubing #6
Very informative, thanks
   / Removing weld seam in tubing #7
Nothing wrong with his method but I don't see myself spending the time to build a tool every time. As he said the weld is never in the same place.
I've done this with a file or a long nose grinder. I usually use the Long Shaft Die grinder from HF to get as deep as I can then finish with a file if I need to.
What surprises me the most is every local metal fabricator/supplier I have gone to says they just use 2-1/2" x 3/16" wall tube for the outer piece. No way I want that much slop in a receiver. I buy 1/4" wall tube and remove the weld.
   / Removing weld seam in tubing #8
Very interesting video, quite informative.
   / Removing weld seam in tubing #9
Video was interesting, thanks;
For 2" receivers they actually make female receiver tube - it's .030" over 2.5" tube, smooth inside. So 2.530" OD, 2.030" ID; A little more expensive per #, but not THAT much. My local steel supplier stocks it, free delivery for orders over $100 (and yes, one stick IS free delivery @ 151 pounds)
YMMV, but with 2 tractors and a hoe I make a LOT of "tinker toys" with that material and 2" x .250" wall... Steve
   / Removing weld seam in tubing #10
With a chisel you can easily peel up a couple inches of seam from each side.
Then file the little bit in the center.
621716d1568777018-removing-weld-seam-tubing-chisel-jpg
Of all those methods I'd get a chisel like the one he had.
Or grind it one-sided myself.
Steve if you have 20 feet I'm coming to your house next time i need it. :cool2:
I've been buying the 18" receiver tube at Harbor freight for $16 and it makes 2 or 3 receivers.
Class III 18 in. x 2 in. Standard Receiver Tube
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
Charlotte County (A50323)
Charlotte County...
Light Tower (A52377)
Scag Mower (A50324)
Scag Mower (A50324)
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
