bcalhoun
I had to buy a new monarch cylinder for my bat wing and I need to know if I will need to bleed the new cylinder when I install it, if so what痴 the process?
Run it up and down 3-4 times and you should be fine.I had to buy a new monarch cylinder for my bat wing and I need to know if I will need to bleed the new cylinder when I install it, if so what痴 the process?
I've never seen a agricultural hydraulic cylinder that has a bleeder screw on it, I would just hook up the lines to it and run it up and down to the end of its stroke in each direction, as you move the piston back and forth it will force the air out.Do I need to loosen the bleeder screw or does it self bleed?
Good point, running it up and down (without depth stops) should flush the air out.I’m going to guess it’s a single acting cylinder, and he is calling port that is plugged with a air orifice a bleed screw.
Aaron Z
That side is normally full of air, it fills the other side with hydraulic fluid to lift the mower.View attachment 621067
not real clear on the terminology but its the silver hex screw at the top of the cylinder, it has a weep hole in it where the fluid sprayed out which is what led to me replacing the cylinder.
Take those depth stops off, lower the mower all the way down, then raise it all the way up a couple of times.
Aaron Z
