GC1705 with Piranha bar.
   / GC1705 with Piranha bar. #11
Pretty nice, man. I was on fence between this or ratchet rake, went with the rake. Theres a dude on YouTube I follow has a piranha bar, did some real nice grading with it, was just shaving off thin layers of soil to get the right pitch.
As I get the Sumac cleared up I have noticed if I work the FEL I can shave off the top soil but it is so uneven that when one of the front tires drops into a low area one of the corners dig in and you really need to work it that is why I wish the FEL valve worked in the 1-2 and 4-5 movement not just 12-6-3-9, tilt-level-drop-raise all in one smooth motion but hay I am getting it figured out, was a little discouraging at first but slowly and surly I am getting it done.
Jim.
   / GC1705 with Piranha bar. #13
I'm too new at working a tractor to be giving advice, but I'm thinking your plan to use box scraper with scarifiers to level, not bad idea. I used the ratchet rake along those lines, just scraping dirt into the low spots, back and forth I went. Not perfect smooth, but definitely now good enough to seed for grass in my yard.
The YouTube dude with the piranha bar, he's also on a gc1710. He's got a lot of interesting vids, Louisiana Tractorworks, check him out.
I just replayed in the deadheading hydrostat thread what i am going to do with the box blade, I will start with one scarifier tooth down in first position and work my way up to using all 4 teeth, going to see how far I can go in turtle-fwd-2200-2400 rpm and R4 tires, it is like a mud clay due to all the rain so those R4 tires get good traction, they really grab and stick, it is hard to get the tires to just spin.
Jim.
put Up double post.
Jim.
Piranha bar got this rock out.
1705 posing for the camera, what a putz hahaha.
Jim.
   / GC1705 with Piranha bar. #17
OK I got to ask a question. When digging that rock out did you have a counter weight on the back? I have never had a loader so I am learning as I go and I have had my back tires off the ground a couple of times. I got some ideas on here about building a DIY box with concrete to weight the back down. I got my piranha bar last week but have not mounted it yet but did not want to do much clearing until I get a counter weight built. Also complicating my use is hills. Most of the brush clearing is on the side of a hill so I will definitely need to make certain I am approaching from below and that I have a counter weight.
I only had my box blade on for counter weight, that rock was flush with the ground, I got the Piranha bar in along side the rock and tilted the bucket up to pry it out, I was surprised at how big it was.
I have not built a regular counter weight yet but I do have a 3 point receiver hitch that I plan on using as a starting point then add some pvc tubes for rake and shovel and a bar guard for chainsaw, build a box and some rebar then add cement, here is my receiver I will build on.
Jim.
   / GC1705 with Piranha bar. #19
No damage to a tooth on the bar, moving that rock? When I was clearing some stuff a little bit ago, I was worried about damaging the teeth on the ratchet rake when moving a boulder, so used the backhoe bucket for that instead.
   / GC1705 with Piranha bar. #20
Jim.
I got my Piranha bar mounted today but just hit a few very small bushes for a quick try out. I am gonna buy a inexpensive 3pt receiver hitch and build a weight box before I do any heavy lifting.
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
2013 AMSIG S/A Solar Towable Message Board (A50322)
2013 AMSIG S/A...
2016 CATERPILLAR 299D2 SKID STEER (A51242)
2016 CATERPILLAR...
2023 CATERPILLAR 299D3 SKID STEER (A51242)
2023 CATERPILLAR...
2 Vintage Metal Signs (A48081)
2 Vintage Metal...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A52128)
3-Point Hitch Root...
