How to remove PTO shaft from slip clutch on rotary cutter?
   / How to remove PTO shaft from slip clutch on rotary cutter? #41
Probably works far better most of the time anyway :)
   / How to remove PTO shaft from slip clutch on rotary cutter? #42
I'm glad it worked loose... but I would have used a tree as the ballast, instead of my purty white Chevy there. LOL
Gotta put it to work. can't have it be a pavement princess. lol
   / How to remove PTO shaft from slip clutch on rotary cutter? #44
Don't have cell phone so Tapatalk does not work for me... I use one of them their old PC thingies....
Dale
Is Tapatalk for cell phones only? I've been trying for years to get it to work on various tablets with very limited success.
   / How to remove PTO shaft from slip clutch on rotary cutter? #45
I use it on my iPad and iPhone
   / How to remove PTO shaft from slip clutch on rotary cutter? #46
I love the tbn app on android. Hate to use a computer after using the app. I hope iphone tbn app is the same, just ordered iphone.
   / How to remove PTO shaft from slip clutch on rotary cutter? #47
Don’t know it’s the same but I use the TBN app on iphone/ipad probably 95%. Rarely use the web version.
   / How to remove PTO shaft from slip clutch on rotary cutter? #48
Congrats on getting it apart, rust is a pain. A neighbor gave me a can of Aerokroil, and it's the best penetrating oil I have ever used. I have read that 50-50 mixture of acetone and ATF works as well, but haven't tried it yet.
If your slip joint is sloppy a shop that repairs semi truck drivelines can repair it....quite possibly cheaper than replacement. Mine was going thump- thump as it rotated, I got it redone for under 100 dollars (quite a few years back). Trusted them with front drive shafts from my 4x4 trucks too.
   / How to remove PTO shaft from slip clutch on rotary cutter? #50
Sooo, are you up and mowing?
2017 Green Thumb 58OSN3 8ft Pressure Washer Trailer (A55787)
2017 Green Thumb...
500BBL WHEELED...
2006 John Deere 120C Hydraulic Excavator (A56857)
2006 John Deere...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
Turfco Mete-R-Matic XL Towable Golf Course Drop-Style Topdresser (A55973)
Turfco...
2017 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2017 Ford F-550...
