How to determine if Yanmar 330D has power steering
   / How to determine if Yanmar 330D has power steering #12
I made a mistake I believe. I used 90wt. gear oil. Not 303Hyd. May want to still check into what is calls for. I tried Hoye and found the Front Axle used 90wt. So I believed that's what I used. Been awhile,10yrs. if not more......
   / How to determine if Yanmar 330D has power steering #13
Cool thanks. Been wanting to swap my fluid but didn't eat to tear the whole top off the thing.
   / How to determine if Yanmar 330D has power steering #14
Gearbox power steering was an option on the 336 so I would believe it was on the 330 as well. If you have it you will find hydraulic lines going down to the steering gear box.
I had this option on my 3110 D
   / How to determine if Yanmar 330D has power steering #16
I expect they would be scarce as hen's teeth. :D You would also need the diverter box that is a part of the system and the lines are sort of special. (hard tubing)
   / How to determine if Yanmar 330D has power steering #17
You could run hydraulic lines in place of the tubing if you found the rest.
   / How to determine if Yanmar 330D has power steering #18
   / How to determine if Yanmar 330D has power steering #19
I bet a hydraulic shop could get you some ends
16 BLADE DISC HARROW (A52708)
16 BLADE DISC...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A56435)
2023 Top Air ATV...
2012 Mitsubishi Fuso FEC52S Cab and Chassis Truck, VIN # JL6AMG1A0CK003828 (A57453)
2012 Mitsubishi...
PAZA 3PT SPIN SPREADER (A52708)
PAZA 3PT SPIN...
Terms & Conditions of (Buying through EquipmentDealz Auction) Continued (A59213)
Terms & Conditions...
BED FROM 2024 FORD F250 SUPER DUTY (A58018)
BED FROM 2024 FORD...
