Truck Ramps - Changing Oil
   / Truck Ramps - Changing Oil #1
SJay
Gold Member
Tri City Area, MI
Bobcat CT225 Tractor, John Deere 4x2 Gator, Husqvarna Zero Turn, John Deere Buck 650 ATV
Got a 2019 Ram 1500 and want to get some ramps so I can do some general maintenance and oil changes. Curious what ramps everyone is using?
   / Truck Ramps - Changing Oil #2
Had a couple sets of 'store bought' ramps that petered out. Finally built my own from .40 retention wood. Built them much more stout that store bought ramps. So stout that I can back my ag tractors up on them to do a PTO shaft swap without loosing fluid.
I've had them for over 10 years now and I'm glad I took the time to build them.
   / Truck Ramps - Changing Oil #3
I also used to have plywood ramps that worked well. I put vertical 4 x 4 supports inside them to insure they wouldn't buckle. However, I now just use jack stands since, with the extended oil change intervals, I rotate tires when I change oil.
   / Truck Ramps - Changing Oil #4
For my 2010 RAM I just slide under the truck on a piece of cardboard. It's tight but it works. Ramps? That's a good idea. I've only been using them for my wife's car. I just use the cheap metal ones from the parts store for that and they've worked fine for a number of years.
   / Truck Ramps - Changing Oil #5
I also used to have plywood ramps that worked well. I put vertical 4 x 4 supports inside them to insure they wouldn't buckle. However, I now just use jack stands since, with the extended oil change intervals, I rotate tires when I change oil.[/QUOTE
Instead of plywood for the ramp tops, I used 1" thick x 12" wide PT planks screwed to 1" wide tapered planks for the sides and fronts all secured with stainless deck screws. On the bottom edges I angle drilled holes and screwed in stainless deck screws protruding just a tad below the bottom surface of the verticals so the ramps would 'bite' into my concrete pad just a might. One issue I had with the old metal ramps as they always wanted to coot on the concrete.
Any pictures??
   / Truck Ramps - Changing Oil #7
I don't have any pictures, but twice I've made my own ramps of 2 x 10 lumber, cut the first one 4.5', then 4.0, 3.5, 3.0, 2.5, 2.0; cut one end of each with a 45 degree angle, stacked them, and screwed each one to the one below, attached a large drawer handle to the side of each one, so they were heavy, but solid wood; no way they could collapse under the weight of a vehicle. The first time I did that was in 1973 to use under a little Winnebago motorhome, and the later one was just to change oil and such on my car and pickup.
   / Truck Ramps - Changing Oil #9
the previous owner of my house left behind a 12x12 rough cut cedar post ~8' long.
I promptly took the chain saw out, and cut a long angle and made a pair of ramps. SOLID wood.... will not buckle!
   / Truck Ramps - Changing Oil #10
Race ramps made in the good old USA "Escanaba Michigan" are hard to beat..I bought a set last year for car/truck/lawn tractor work.Very sturdy.. Car and Auto Ramps for Service, Loading and Display - Race Ramps
I'm a Michigander too but 317 clams for a set of ramps that look just like the ones I built from, .40 retention for about 40 bucks, ain't gonna happen in Deerfield. The Yoopers will have to keep eating smoked fish...... Eh?
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
2008 Ford Escape XLT SUV (A51694)
2008 Ford Escape...
2012 Ram 3500 Chassis Pickup Truck, VIN # 3C7WDTAL9CG134341 (A51572)
2012 Ram 3500...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
