Truck Ramps - Changing Oil
   / Truck Ramps - Changing Oil #1
SJay
Gold Member
Tri City Area, MI
Bobcat CT225 Tractor, John Deere 4x2 Gator, Husqvarna Zero Turn, John Deere Buck 650 ATV
Got a 2019 Ram 1500 and want to get some ramps so I can do some general maintenance and oil changes. Curious what ramps everyone is using?
   / Truck Ramps - Changing Oil #2
Had a couple sets of 'store bought' ramps that petered out. Finally built my own from .40 retention wood. Built them much more stout that store bought ramps. So stout that I can back my ag tractors up on them to do a PTO shaft swap without loosing fluid.
I've had them for over 10 years now and I'm glad I took the time to build them.
   / Truck Ramps - Changing Oil #3
I also used to have plywood ramps that worked well. I put vertical 4 x 4 supports inside them to insure they wouldn't buckle. However, I now just use jack stands since, with the extended oil change intervals, I rotate tires when I change oil.
   / Truck Ramps - Changing Oil #4
For my 2010 RAM I just slide under the truck on a piece of cardboard. It's tight but it works. Ramps? That's a good idea. I've only been using them for my wife's car. I just use the cheap metal ones from the parts store for that and they've worked fine for a number of years.
   / Truck Ramps - Changing Oil #5
I also used to have plywood ramps that worked well. I put vertical 4 x 4 supports inside them to insure they wouldn't buckle. However, I now just use jack stands since, with the extended oil change intervals, I rotate tires when I change oil.[/QUOTE
Instead of plywood for the ramp tops, I used 1" thick x 12" wide PT planks screwed to 1" wide tapered planks for the sides and fronts all secured with stainless deck screws. On the bottom edges I angle drilled holes and screwed in stainless deck screws protruding just a tad below the bottom surface of the verticals so the ramps would 'bite' into my concrete pad just a might. One issue I had with the old metal ramps as they always wanted to coot on the concrete.
Any pictures??
   / Truck Ramps - Changing Oil #7
I don't have any pictures, but twice I've made my own ramps of 2 x 10 lumber, cut the first one 4.5', then 4.0, 3.5, 3.0, 2.5, 2.0; cut one end of each with a 45 degree angle, stacked them, and screwed each one to the one below, attached a large drawer handle to the side of each one, so they were heavy, but solid wood; no way they could collapse under the weight of a vehicle. The first time I did that was in 1973 to use under a little Winnebago motorhome, and the later one was just to change oil and such on my car and pickup.
   / Truck Ramps - Changing Oil #9
the previous owner of my house left behind a 12x12 rough cut cedar post ~8' long.
I promptly took the chain saw out, and cut a long angle and made a pair of ramps. SOLID wood.... will not buckle!
   / Truck Ramps - Changing Oil #10
Race ramps made in the good old USA "Escanaba Michigan" are hard to beat..I bought a set last year for car/truck/lawn tractor work.Very sturdy.. Car and Auto Ramps for Service, Loading and Display - Race Ramps
I'm a Michigander too but 317 clams for a set of ramps that look just like the ones I built from, .40 retention for about 40 bucks, ain't gonna happen in Deerfield. The Yoopers will have to keep eating smoked fish...... Eh?
1997 East Manufacturing Walking-Floor Trailer, VIN # 1E1U1X287VRE22897 (A51572)
1997 East...
2017 Club Car Carryall 300 Utility Cart (A51691)
2017 Club Car...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
2018 KOMATSU D51PX-24 CRAWLER DOZER (A51246)
2018 KOMATSU...
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A52472)
2013 TEXAS PRIDE...
1985 Ford Ltl9000 Tender Truck (A52748)
1985 Ford Ltl9000...
