DerbyRunner
I recall years ago, someone commented to me - "How hard can plumbing be? Water always flows downhill right?"
Very appropriate. So to ask, in a closed pipe system, why would water flow uphill to the first radiator? Unless there is some other source of energy, it would not. Water would just flow through the main line without going "up" then "down" to/from the radiators.
I believe the source of energy at the 3/4 line is heat rise. In the section you created with the modification, you caused a second need to flow water upward, except this doesn't have any tap to the main line so no "heat rise" on that section. I believe that is where your problem is.
I'm confused why your diagram shows two radiators before the changes, and 3 radiators after the changes? I would bet if you plumbed the line out of the 2nd radiator over to the 1/2 inch return to the main line those two connected radiators would work fine. Of course the 3rd one would be orphaned at that point.
