Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #9,831
We have a ton of red squirrels around too with all the softwood cones. Baffles work on the winter bird feeders and once in a while one gets into the garage which bothers me. But they seem to be a sucker for a rat trap baited with peanut butter with embedded sunflower seeds. The one that stay outside are fine.
gg
   / Tractors and wood! Show your pics #9,832
A couple posts back OP showed his son's blade setter/sharpener and there seemed to be some interest in it. I just saw this Woodmizer setter on the FF and thought maybe someone would be interested but I don't know any thing about this type equipment. I am from the hand setting and filing of carpentry hand saw days.
http://forestryforum.com/board/index.php?topic=107750.msg0#new
gg
gg
   / Tractors and wood! Show your pics #9,833
It's coming, I see geese fly over this afternoon, heading to S.C. I presume. So to get prepared, I swept the chimney, it needed it, fixed up my kindling shelf and pumped up tires on my firewood cart. The shelf I had was to small for the bundle of kindling so I made it bigger with removable stakes, now I can take a whole bundle and slide it in easy without playing 52 pickup. It was another one of those 1 hr projects that took 3 hours, so I ran out of time to get my saws ready, wanted to clean and sharpen before next weekend, guess I'll kick that can down the road a couple days.
   / Tractors and wood! Show your pics #9,834
View attachment 623886 View attachment 623887 View attachment 623888
Saw a couple flocks of geese today also , not sure where they’re going , I’m in Chicago . What species is your kindling? I use pine ( I have lots of cutoffs) . Ever use fat wood for starting? I’ve enough fat wood stumps to last the rest of my life I think, something new to me since coming to SC.
I need to sweep my chimney also and get my wood set up at the house also, fall is coming����
   / Tractors and wood! Show your pics #9,835
Saw a couple flocks of geese today also , not sure where theyæ±*e going , I知 in Chicago . What species is your kindling? I use pine ( I have lots of cutoffs) . Ever use fat wood for starting? I致e enough fat wood stumps to last the rest of my life I think, something new to me since coming to SC.
Mix bag of soft wood kindling, mostly hemlock these bundles were cut up last year. I had SS liner put in my chimney 2002, stayed fairly ckean first 5 years, then it got a little creosote build up, cleaned it with a steel brush now every year I have to clean it, sometime twice a year, after I read not to use a steel brush on SS liner I bought a plastic brush.
   / Tractors and wood! Show your pics #9,836
I pulled out my tippy dumpster and loaded it with firewood. I wish I had a dozen more dumpsters but they’re expensive. It would be nice if my M59 would lift that but I doubt it will.
   / Tractors and wood! Show your pics #9,837
Yes, only a plastic chimney brush on stainless. Buildup brushes right off.
   / Tractors and wood! Show your pics #9,838
I have a question. Here is a picture of my woodshed. It is 4 ft deep x 24 ft long x 8 ft high. No matter how I stack my wood after a couple months it starts to fall out. I have to run the 2x6 's to hold it in. As you can see in the right side of stack i throw in a lot of cross pieces of wood to try to make the stack lean against the back wall. The back wall is plywood. The shed faces SSW so it gets sun from noon on.
Any suggestions how to stack so wood stays in w without help.20190602_141435.jpeg
   / Tractors and wood! Show your pics #9,839
A long high row of stacked wood like you have is always drawn towards the sun and eventually tips over. Green wood as it dries unevenly from the sunny side. I would try putting in some vertical posts, 2X4's or poles, every 6' or so so you have several bays instead of one long one. Or some more plywood sections like you have in there all ready. That way you won't have a middle section hanging out so far it will tip. I have two 7-1/2 foot wide by 7 foot tall bays and it stays OK.
gg
   / Tractors and wood! Show your pics #9,840
You have something against Air conditioning?? I could not live in a house without!!
You need heat in the dead of winter, and Air conditioning the rest of the year!! :D
Nothing against it just don't need it. Our 1st story stays around 76* when it is 90*+ outside. The beauty of having half a block house not to mention our valley usually has a slight breeze and we have window fans.
2017 CATERPILLAR 299D2 SKID STEER (A52705)
2017 CATERPILLAR...
2007 Ford F-250 Crew Cab Pickup Truck (A51692)
2007 Ford F-250...
UNUSED DIGGIT 20'X30' METAL GARAGE CARPORT SHED (A54757)
UNUSED DIGGIT...
CURTIS 55CFM AIR COMPRESSOR (A54757)
CURTIS 55CFM AIR...
2018 Ford Fusion Hybird Sedan (A53424)
2018 Ford Fusion...
gravely riding mower (A53424)
gravely riding...
